Serial Communication Problem
Results 1 to 24 of 24
    leemin's Avatar
    leemin Guest
    Default help
    To anyone else who may be interested in receiving a serial string, reading it and then doing something based upon a character(s) received, let me know and I'll post some really nice code to play with.
    yupe. i need a program to receive a serial string, reading it and then doing something. my string is something like this X-Addr-Mode-Data(30bytes)-Y
    where X stand for SOT and Y stand for EOT. Addr is use to indicate the dedicated address value i want to send data.
    my code is something like below:
    include "modedefs.bas"
    DEFINE SHIFT_PAUSEUS 20
    define OSC 20
    DEFINE HSER_CLOERR 1 ' automatic clear overrun error
    TRISA=%11110000
    TRISB= %11111011
    TRISC.6 = 1
    TRISC.7 = 0
    symbol Addr_Data_In=porta.4
    symbol en=porta.3
    symbol stb=porta.2
    symbol clk=porta.1
    symbol data_out=porta.0
    SPBRG = 32 ' Set baud rate to 9600
    RCSTA = $90 ' Enable serial port and continuous receive
    TXSTA = $24 ' Enable transmit and asynchronous mode
    RCIF VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty)
    TXIF VAR PIR1.4 ' Transmit interrupt flag (1=empty, 0=full)
    OERR var RCSTA.1 ' Overrun error
    CREN var RCSTA.4 ' Continuous receive
    ADCON1=6
    display: if RCIF then
    i=RCREG
    if i != "X" then discard
    redo: hserin 500,discard,[i]
    if i="Y" then discard
    serialstring[counter]=i
    counter=counter+1
    goto redo
    discard: if i="Y" then success=1
    if success then
    cren = 0
    if (serialstring[0] <> address_Value) then reset
    if serialstring[1] = $30 then turn_off_led
    serialstring[2]=a29
    serialstring[3]=a28
    serialstring[4]=a27
    serialstring[5]=a26
    serialstring[6]=a25
    serialstring[7]=a24
    serialstring[8]=a23
    serialstring[9]=a22
    serialstring[10]=a21
    serialstring[11]=a20
    serialstring[12]=a19
    serialstring[13]=a18
    serialstring[14]=a17
    serialstring[15]=a16
    serialstring[16]=a15
    serialstring[17]=a14
    serialstring[18]=a13
    serialstring[19]=a12
    serialstring[20]=a11
    serialstring[21]=a10
    serialstring[22]=a9
    serialstring[23]=a8
    serialstring[24]=a7
    serialstring[25]=a6
    serialstring[26]=a5
    serialstring[27]=a4
    serialstring[28]=a3
    serialstring[29]=a2
    serialstring[30]=a1
    serialstring[31]=a0
    reset: cren=1 ' Enable receiver
    goto display
    Apr 2005
    Virginia
    I need to sift through my code and pull out the serial stuff (it's a long code as it stands) and reply to you this evening. What PIC are you using by the way?
    Also, could you describe what you want to do again in more detail? I'm a little confused when you say X stands for SOT and Y for EOT. I'm still a newbie in programming, but I'm sure I can help you with this. So far I gather you want to receive a serial string and read it. You then want the PIC to do something by way of transmitting another serial string and placing the characters in a specific location along that string? Which is no problem I just want to make sure I'm giving you what you want.
    -Tony
    Apr 2005
    Virginia
    Default Sample Code
    Okay, I brought this home, tweaked it with a different programmer and when I try to compile it, it says it is unable to "fit variables". I'm think this will work as it stands, but you may find some errors on my part.
    In any event, this waits for serial data and once received looks at the first two characters to be sure the string is what you expect it to be. You can take this out if your serial input changes every time (the first two and last two characters in a string). If you ever expect more than 40 bytes on a single serial string be sure to change that in the variable definitions.
    The branch command really comes in handy for looking at a single character at a specific location in the string and doing different things instead of using the if command.
    Take a look at this and see if it helps. Feel free to ask questions.
    -Tony
    Apr 2005
    Virginia
    Default P.s.
    ASII Table - All important to serial comms - Check this out:
    http://www.lookuptables.com/
    leemin's Avatar
    leemin Guest
    Exclamation
    ok. thanks for you all previous help. i can work with the USART interrupt with my code already but now i encounter with a new problem.
    im using 16f877a.
    i need to receive a string of command from computer. then execute some function after received a valid command. now i need to execute the blinking effect by toggling the enable pin to let the led on and off continuosly untill another set string of command come in and either stop blinking or continue blinking.
    but now i found out that the blinking sub-routine is a dead loop. when i continuosly execute the blink function and a new string command come in from computer my firmware will hang there.
    any solution for this?
    i need you all suggestion.
    thanks
    Mentor, Ohio
    Smile
    Hi Leemin,
    It's a great idea to have the micro do as much as possible but sometimes it's necessary to have external hardware do some work to free up the micro to do other things more important. Add a gated pulsing circuit that you only need the micro to turn on and off. This can be a single chip circuit like using a CD4093 or even a CD4060. A CD4060 lets you choose flash rates juct by selecting the appropriate output. These are simple circuits and only require a few discretes to finish the job. Let the micro do the more serious stuff.
    BobK
  1. Replies: 18
    Last Post: - 4th July 2017, 15:26
  2. serial communication problem
    By kindaichi in forum Serial
    Last Post: - 11th March 2010, 17:37
  3. Replies: 5
    Last Post: - 20th March 2006, 02:34
  4. Problem in Serial Communication
    By uuq1 in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 08:17
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
