Hello All
i am presently working on a project which has to send SMS msg when certain conditions are reached.
this works fine as you can see from the code here.
my question is "Is it possible to send the same SMS msgs to say 5 different mobile phone numbers without having to do 5 different subs
as i need to notify 5 different mobile numbers which the same message.
Isaac
Code:SMS: HSEROUT[ "AT" ,13] 'Sending "AT" and Carraige return to GSM module ' If its ok, the it will send a response back : "OK" HSERIN 5000, SMS,[WAIT("OK")] ' wait for response ok for 5 seconds ' if it times out, it will go back to SMS and retry 'If GSM Module is OK, will send response "OK" ' Other wise it will go back to SMS and retry HSEROUT["AT+CMGF=1",13] 'Here the GSM module is being entered in TEXT MODE. HSERIN 5000, SMS,[WAIT("OK")] ' wait for response ok for 5 seconds ' if it times out, it will go back to SMS and retry HSEROUT[ "AT+CMGS=+4475--------"] 'Here the GSM module is told the desitnation phone number. 'This is done by sending string "AT+CMGS= desitnation mobile number" HSEROUT[13] HSERIN 5000 , SMS, [WAIT(">")] HSEROUT[ " Battery Volts too Low" ,10,13]'result HSEROUT[ 26] ' this is ASCII for Ctrl+Z HSERIN 15000 , SMS,[WAIT("+CMG")] 'Here we are waiting for a string CMG. If that is received it means that the message 'has been transmitted successfuly! LCDout I, Clr lcdout I,Line1+3," Batt Alert " lcdout I,Line2+2," SMS MSG Sent to" lcdout I,Line3+2," +4475---------- " lcdout I,Line4+4," Msg sent OK" LOW GSM_EN pause 500 return
