Using Variables with PAUSE/PWM Commands
Results 1 to 5 of 5
    Default Re: Using Variables with PAUSE/PWM Commands
    Should I be using instead:
    Symbol FLASH_ON = 1500
    Symbol FLASH_OFF = 500
    FLASH_ON VAR BYTE
    FLASH_OFF VAR BYTE
    Your values are larger than a BYTE.
    Yeah, they need to be WORD-size variables to fit values larger than 255....
    But if you're not going to change the value at runtime there's no real need to have them as variables, you might as well make them constants:
    FLASH_ON CON 1500
    FLASH_OFF CON 500
    Saves on both RAM and flash memory.
    Thanks all! I'll use constants for now but eventually it will read from a pot input.
