EEPROM write with USB
Results 1 to 14 of 14
    Jun 2011
    Default Re: EEPROM write with USB
    Cleaned up the code and the comments a little..
    ' program for pic18f14k50
    Include "cdc_desc.bas" ' Include the HID descriptors
    Define OSC 48
    Define ADC_BITS 10
    Define ADC_clock 6
    Define ADC_sampleus 3
    ' initial EEPROM values (output = input)
    DATA WORD 0,WORD 16,WORD 32,WORD 48,WORD 64,WORD 80,WORD 96,WORD 112,WORD 128
    DATA WORD 144,WORD 160,WORD 176,WORD 192,WORD 208,WORD 224,WORD 240,WORD 256
    DATA WORD 272,WORD 288,WORD 304,WORD 320,WORD 336,WORD 352,WORD 368,WORD 384
    DATA WORD 400,WORD 416,WORD 432,WORD 448,WORD 464,WORD 480,WORD 496
    DATA WORD 512,WORD 539,WORD 566,WORD 593,WORD 620,WORD 647,WORD 674,WORD 701,WORD 727
    DATA WORD 754,WORD 781,WORD 808,WORD 835,WORD 862,WORD 889,WORD 916,WORD 943
    DATA WORD 970,WORD 997,WORD 1024,WORD 1024,WORD 1024,WORD 1024,WORD 1024,WORD 1024
    DATA WORD 1024,WORD 1024,WORD 1024,WORD 1024,WORD 1024,WORD 1024,WORD 1024
    DATA WORD 1024
    EEPROM 230, [254,0,210,0,190,0,100,0,60,0,40,0,30,0,0,0] 'temp out table word size ohm out values
    'eeprom 244, [147,147,130,130,125,125,125,120,120,115,115,115,11 5,115,115,115] 'desired afr table
    'eeprom 250, [122,0] 'displacement scalar
    'eeprom 252, [ 50] 'min load for auto tune
    eeprom 253, [ 64] 'tube size scalar tube area
    'eeprom 255,[ 254] 'autotune check bit
    BUFFER Var Byte[16]
    CNT Var Byte[16]
    MAFIN var word ' 10 bit a/d input value
    MAFOUT var byte[6] ' string for usb debugging
    OUTPUTVAL VAR WORD ' output value to DAC
    TEMPVAL VAR WORD ' input temporary
    TABLEHIGH VAR WORD ' high table value
    TABLELOW VAR WORD ' low table value
    TEMPVAL2 VAR WORD ' input temporary #2
    FLOW var word ' flow value from input lookup table
    INPUTTABLE con ext
    MAFSCALAR var word ' scalar for input flow value correction
    FLOWINVAL var word ' output temporary
    FLOWINVAL2 var word ' output temporary #2
    FLOWFINAL var word ' flow value after mafscalar correction
    TRISC = %11000000 'make port c6,7 input make port c 012345 input
    ADCON2 = %10000000
    ANSELH = %00000010
    USBInit ' Get USB going
    HIGH PORTC.2 ' Serial D-A chip select off
    startloop:
    Adcin 9, mafin ' take value from an9 place it in mafin
    READ 253, mafscalar ' read eeprom value at location 253 place it in mafscalar
    goto overdata
    '0-5v input sensor transfer function in 2.9 tube adc counts to flow
    asm
    inputtable
    DW 0, 0, 0, 0, 0, 7, 12, 16, 20, 24, 28, 33, 39, 45, 53, 62, 72, 83, 94, 107
    DW 121, 136, 152, 169, 188, 208, 229, 252, 277, 304, 332, 363, 395, 430, 468
    DW 507, 549, 594, 641, 691, 743, 798, 855, 915, 977, 1043, 1110, 1181, 1255
    DW 1331, 1410, 1493, 1579, 1668, 1761, 1858, 1960, 2065, 2175, 2289, 2408, 2532
    DW 2659, 2791, 2925, 2925
    endasm
    overdata:
    usbservice
    tempval = mafin >> 3 ' shift input for table lookup devide by 8
    tempval2 = tempval & %1111111111111110 ' clear last bit for WORD lookup
    'get table high and low values
    READcode (inputtable+tempval2+2),tablehigh.BYTE0
    READcode (inputtable+tempval2+3),tablehigh.BYTE1
    READcode (inputtable+tempval2),tablelow.BYTE0
    READcode (inputtable+tempval2+1),tablelow.BYTE1
    'Table Interpolation
    tempval = mafin & %0000000000001111 ' get interpolation value add 1 less than table spacing to mafin 15
    IF tablehigh >= tablelow THEN ' get space between table values
    tempval2 = tablehigh - tablelow '
    ELSE '
    tempval2 = tablelow - tablehigh '
    ENDIF '
    tempval = tempval2 * tempval 'multiply high/low diff by interp value
    flow = tempval >> 4 'divide by table spacing 16
    IF tablehigh >= tablelow THEN ' offset table value by calculated
    flow = flow + tablelow ' interpolation value
    ELSE '
    flow = tablelow - flow '
    ENDIF '
    flowsub:
    usbservice
    mafscalar = mafscalar/64
    flow = flow * mafscalar 'multiply flow value by maf housing size scalar
    flowfinal = flow
    if flowfinal >= 511 then goto mafouthighloop ' splint flow to ad counts conversion between
    ' two tables with different spacing for resolution
    mafoutlowloop:
    flowinval = flowfinal /8 ' shift input for table lookup take 9 bit flow number change to 0-64 number of memory locations
    flowinval2 = flowinval & %1111111111111110 ' clear last bit for WORD lookup
    READ flowinval2+2,tablehigh.BYTE0
    READ flowinval2+3,tablehigh.BYTE1
    READ flowinval2,tablelow.BYTE0
    READ flowinval2+1,tablelow.BYTE1
    flowinval = flowfinal & %0000000000000111 ' get interpolation value add 7 to adval
    flowinval2 = tablehigh - tablelow '
    ELSE '
    flowinval2 = tablelow - tablehigh '
    ENDIF '
    flowinval = flowinval2 * flowinval 'multiply high/low diff by interp value
    outputval = flowinval /8 'divide by table spacing 8
    outputval = outputval + tablelow ' interpolation value
    ELSE '
    outputval = tablelow - outputval '
    goto outputsub
    mafouthighloop: '
    usbservice
    flowinval = flowfinal /64 ' shift input for table lookup take 14 bit mafin number change to 56-120 number of eeprom locations
    ' 'get table high and low values
    READ flowinval2+56+2,tablehigh.BYTE0 ' values start at 56 instead of 65 because 512/64 is 8
    READ flowinval2+56+3,tablehigh.BYTE1
    READ flowinval2+56,tablelow.BYTE0
    READ flowinval2+56+1,tablelow.BYTE1
    flowinval = flowfinal & %0000000000111111 ' get interpolation value add 63 to adval
    ELSE '
    ENDIF '
    outputval = flowinval /64 'divide by table spacing 64
    ELSE '
    outputsub:
    usbservice
    mafout[0] = mafin.byte1 'place variables into usb buffer string
    mafout[1] = mafin.byte0
    mafout[4] = outputval.byte1
    mafout[5] = outputval.byte0
    mafout[2] = flowfinal.byte1
    mafout[3] = flowfinal.byte0
    HPWM 1,127,outputval ' can't figure out how to snd values lower than 2.9hz
    ' Wait for USB input
    tempval = outputval << 2 ' shift output left 2 bits(LTC1661 DtoA)
    tempval = tempval + %1001000000000000 ' add control code(load DAC A)
    LOW PortC.2 ' Enable DtoA chip
    Shiftout PORTC.0,PORTC.1,1,[tempval\16] ' Serial output to DtoA conv
    High PORTC.2 ' Deselect DtoA chip
    idleloop:
    USBService ' Must service USB regularly
    cnt = 16 ' Specify input buffer size
    USBIn 3, buffer, cnt, startloop
    ' Message received
    outloop:
    USBOut 3, mafout, 6, outloop
    Goto startloop
    Jun 2011
    Sorry for not using "code"
     Define  OSC     48
     Define  ADC_BITS 10
     Define  ADC_clock 6
    DATA WORD 1024
    'eeprom 244, [147,147,130,130,125,125,125,120,120,115,115,115,115,115,115,115] 'desired afr table
    BUFFER Var Byte[16]
    CNT Var Byte[16]
    INPUTTABLE con ext
    ADCON2 = %10000000
    ANSELH = %00000010
    startloop:
     goto overdata
    asm
    inputtable
    endasm
    overdata:
     usbservice
     ELSE                                '
     ENDIF                               '
     ELSE                                '
     ENDIF                               '
    flowsub:
     usbservice
     flowfinal = flow
    mafoutlowloop:
     ELSE                                '
     ENDIF                               '
     ELSE                                '
     goto outputsub
    mafouthighloop:                              '
     usbservice
     ELSE                                '
     ENDIF                               '
     ELSE                                '
    outputsub:
     usbservice
    idleloop:
    ' Message received
    outloop:
     Goto startloop
    I would make it easier (for me anyway) to help if you broke the problem down, approach it block by block.
    Are you able to send data to the MCU?
    Or is the problem with the EEPROM.
    I have not studied you code...
    Jun 2011
    I can send and receive data to the mcu. I'm using the usbout command for debugging right now. It sends 3 16 bi twords in one buffer to hyperterminal right now. I just can't figure out how to send a specific value to the mcu and have it wait for 256 byte of data and rewrite the contents of the eeprom with those values. I would also lite to dump the contents of the mcu eeprom back to my pc.
    To start with, the DATA and EEPROM commands only work at compile time. Use READ and WRITE during run time.
    Concept to receive data via USB then WRITE to eeprom.
    Send a small array to the MCU then check the array for a specific value.
    If the value is X the jump to a WHILE or DO loop.
    Wait for data to be recieved that you want to WRITE to the eeprom.
    Use a FOR/NEXT loop to loop through the array received via USB, (this will be a different array/buffer than before)
    WRITING each byte of the array to the next address of the eeprom.
    When finished change the variable X to another value that do not mean GOTO the DO loop.
    RETURN to main program.
    These may help
    http://www.picbasic.co.uk/forum/show...rray+to+eeprom
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    I am not in a place to write code at the moment but you may get the idea.
    Jun 2011
    I think this is what you intended for me to do.. I'm not sure how to advance the array location in the loop. You will see my comment in the code. Thank you again for the help!
     usbservice
    doloop:
           inbyte = 1
           USBin 3, action, inbyte, doloop2        ' Get a char from usb port
    verify:
           IF action = 102 THEN   ' Verify connection
           USBout 3, action, 1, verify
           ENDIF    ' end of verify action
         '  IF action = 117 THEN  ' Write EEPROM
         '  USBOUT 3, action, 1, doloop2
         '  tempval = 0
    tlabel2:
         '  USBin 3, char, inbyte, tlabel2
         '  WRITE tempval, char
         '  USBout 3, char, 1, startloop
          ' tempval = tempval + 1
          ' IF tempval < 255 THEN tlabel2
         '  ENDIF ' end of Write action
    valuesout:
           IF action = 99 THEN    ' Return last input and output
           USBout 3, mafout, 6, valuesout
           ENDIF ' end of IO action
           IF action = 107 THEN   ' Dump EEPROM
           tempval = 0
    Dumploop:
           Read tempval, epromdump[0]  'epromdump is a 256 byte array
            tempval = tempval + 1 'advance to the next eeprom location
            'not sure how to advance places in the array for the new eeprom value
            USBout 3, epromdump, 256, dumploop
    Check at the front of the PBP manual on arrays. You use a FOR loop to scan through the array, using a variable as position pointer.
    Have you considered using Darrel's USB interrupt routine?
    http://darreltaylor.com/DT_INTS-18/home.html
