Hi all,
I am trying to use MPLAB 8.80, PicKit3 and PICBasic Pro 3 to debug some simple PBP 3 basic code in a PIC16F690.
I have my PBP 3 code compiling and working in MicroCode Stuido and MPLAB..... but can not get the debugging working
Using MPLAB traditionally with C or ASM... I am required to select the TAB in MPLAB for debug or release mode.... yet there is no TAB when PBP3 code project is used.
What steps have I missed? OR is there no debugging options with these set of tools?
Thanks in advance Joseph
Compiling output screen
Executing: "C:\PBP3\PBPMPLAB.BAT" -ampasmwin -k# -p16F690 "C:\PBP3\EXAMPLES\LABX20-16F690\ADC_ Joseph.pbp"
PBPMPLAB.BAT 4.0.0.0
Using MPASM from C:\Program Files\Microchip\MPASM Suite\.
Executing: "C:\PBP3\PBPX.EXE" -ampasmwin -k# -p16F690 "C:\PBP3\EXAMPLES\LABX20-16F690\ADC_ Joseph.pbp"
PICBASIC PRO(TM) Compiler 3.0.5.1, (c) 1998, 2012 microEngineering Labs, Inc.
All Rights Reserved.
Trial version. 5 days left.
Warning[205] C:\PBP3\EXAMPLES\LABX20-16F690\ADC_ JOSEPH.ASM 29 : Found directive in column 1. (__config)
Debug output during debug programming and debugging.
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.26.81
Firmware type......................Midrange
PICkit 3 Connected.
Device ID Revision = 00000006
Programming...
Programming/Verify complete
Running...
PK3Err0040: The target device is not ready for debugging.
Please check your configuration bit settings and program
the device before proceeding.
Configuration bits
Address Value Field Category Setting
2007 3FF4 FOSC Oscillator Selection bits INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN
WDTE Watchdog Timer Enable bit WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
PWRTE Power-up Timer Enable bit PWRT disabled
MCLRE MCLR Pin Function Select bit MCLR pin function is MCLR
CP Code Protection bit Program memory code protection is disabled
CPD Data Code Protection bit Data memory code protection is disabled
BOREN Brown-out Reset Selection bits BOR enabled
IESO Internal External Switchover bitInternal External Switchover mode is enabled
FCMEN Fail-Safe Clock Monitor Enabled bitFail-Safe Clock Monitor is enabled
