Have a variable like
Temp VAR BYTE
Then swap the variables in your array.
Your new code will look like below.
        '-------------- Low Address /High Address /Data / Inv Data bytes  --------------
   For T = 1 to 4
    FOR Index = 7 TO 0 step -1               ' Loop for 8 bits data start at bit 7-0 and send
       temp = STDByte[T]
       IF temp.0[Index] = 0 THEN             ' Get polarity of each data bit to send
        Space = Zero                         ' Pulse time = Burst (560us) + Zero (560us) = 1.12mS for a "0" data bit
        Space = One                          ' Pulse time = Burst (560us) + One (1680us) = 2.24mS for a "1" data bit
       STDByte[T] = temp
       GPIO.0 = 0                            ' Set Output low
       pauseus Burst                         ' load the burst for 0.56ms
       GPIO.0 = 1                            ' Set Output high
       pauseus space                         ' High for duration of either Zero or One value ,for each address/data b
       Total[T] = Total[T] + space + burst   ' store total time of string
    NEXT Index                               ' Loop until 8 data-bits sent of DByte(X)
   Next T
