How do I check (or set) a group of consecutive bits within a byte?
Results 1 to 14 of 14
Threaded View
  1. #7
    Mar 2009
    Default Re: How do I check (or set) a group of consecutive bits within a byte?
    Thanks guys, since the only difference between ADC channel6 & adc channel 7 is 1 bit, I actually I think i've figured a workaround, something like this...
    the code below assumes ADCON0 set as something like 11101 to start with (bit 2-6 set the ADC channel, so this would be ADC channel 7 selected)
    if adcon0.2 = 1 then ' if bit 2 is set then ADC Channel must presently be CH7
    adccon.2 =0            ' clear bit 2, to set ADC channel to Channel 6
    adccon0.2 = 1         ' if adcon.2 wasn't set as a '1' then ch6 must have been active therefore now set bit 2 to make AD ch7 active.
    I think that should toggle between ADC ch6 & ch7 on successive calls?
