Powering and reset PIC16LF88 problem
Results 1 to 4 of 4
    Sep 2005
    France
    Default Powering and reset PIC16LF88 problem
    HI,
    I'm working on a GPS project. The pic16lf88 may be powered from 1 or/and 2 sources (GPS)
       OSCCON =100000
       TRISA =010000
       TRISB =000101
       ANSEL =010000      'an4 analog not used at this time
       PORTA = 0
       PORTB = 0
       clear
       led    var     porta.0
       way1   var     portb.0
       way4   var     portb.2
       X      VAR     WORD
       pause 10
       HIGH PORTA.3    ' powering antenna
       mainloop:
       X = X + 1
       IF X = 10000 then
       toggle PORTA.0  'led
       X = 0
       IF way1 = 1 and way4 = 1 then
       low PORTB.4
       HIGH PORTB.7
       goto mainloop
       if way4 = 1 then
       PORTB.4 = 1
       PORTB.7 = 0
       if way1 = 1 then
       PORTB.7 = 1
       PORTB.4 = 0
       goto mainloop
    When my pic is powered from
    way1 = ok
    way2 = ok
    way1 + way2 = ok
    way1 + way2, then cutting power from way2 = ok
    way1 + way2, then cutting power from way1 = NOT OK PORTA.3 (antenna) becomes LOW !!!
    I have tried to play with BOREN without success. When enabled the circuit doesn't work at all.
    Simulation works great with ISIS, not with real circuit.
    Can someone help ?
    Dec 2010
    Default Re: Powering and reset PIC16LF88 problem
    Note this diagram does not actually show power connections to the PIC.
    This looks unnecessarily complex, and it appears the PIC can choose it's own power for some reason. If you want to power a PIC from either of 2 sources, why not simply throw out this entire circuit except for D3/D4 with the anode of D3 connected to WAY1 and the anode of D4 to WAY4? (Common Cathode to VDD).
    Sep 2005
    France
    Hi Charlie,
    Yes it is because of the ISIS software (hiden powering rails). But power connection is from D1+D2 (common cathode)
    (D3+D4 is used for powering RF and control circuit: not on this shematic)
    Cannot change this... PCB's already made !
    Dec 2010
    What supply voltages are you using? (And if the answer is 5V, remove the zener diodes and try again to see if it works.)
