Multi-digit word variable to string
Results 1 to 40 of 44
Threaded View
  1. #19
    Default Re: Multi-digit word variable to string
    Now i'm trying to figure out how to add the remainder in the command.
    i hope this is not a medical diagnostic device
    your temperature calculation is not accurate and the remainder calculation is mathematically incorrect
    temperature  = tempir/50         ' based on the manual we need to divide by 50 or 0.02
    temperature  = temperature - 273 ' subtract 273 for Degree in C,actually is 273,15
    yields the temp in deg C to about 1 deg of resolution with an error of +- 1 degree
    remainder    = (tempir*2)//100   ' multiply x 2 and get the remainder //100
    calculated the 100 modulus of the temp in deg kelvin
    adding them together is nonsense , trying to display a two decimal point result is from any of these results is just not right
    Name:  Screenshot 2021-12-19 163013.jpg
    wtf tempir = (temp.highbyte << 8) + temp.lowbyte ;just Nooooo! its the hardest most convoluted way i have ever encountered to go
    tempir = temp which serves no purpose anyway
    don't like this either, it pisses away too much resolution hence its not particularly accurate
    ;this is good  although it could be even more accurate [temperature  = temp*2  - 27315 ; temp x 2 - 273.15*100 ] >==>temperature*100] if the raw value won't exceed 32768
    temperature  = (temp  - 13657)<<1  ; (temp-[273.15*50]) x 2   <==> temperature*100; is good
    i make the assumption temperature * 100 is the value required by the slider display
    tempir and remainder are not needed
    display like this
    '------------------------------------------------------------------------------*'                    IR  Display 1 the parameters                              *
    display: ' IR TEMP
    hserout2 [$73,$00,$02,$12,$00,$ff,"IR TEMP:",00]
    Hserin2  timeout,error,[wait(6)]
    hserout2 [$73,$08,$02,$12,$F8,$00,dec2 temperature/100,".",dec2 temperature//100,"*C",00]
    gosub checksum2
    hserout [$01,$0F,$00,temperature.highbyte,temperature.lowbyte,IRCS]
    Hserin  timeout,error,[wait(6)]
    '                               CHECKSUM IR                                    |
    checksum2:
    IRCS = 0
    IRCS = $01 ^ $0F ^ $00 ^ temperature.highbyte ^ temperature.lowbyte
    then lets have a look at the i2c stuff , its not right either really
    ps if negative temps are possible then additional code req
