Crashing 16F628 Code
Results 1 to 4 of 4
    hhaplant's Avatar
    hhaplant Guest
    Default Crashing 16F628 Code
    My microcontroller stops working within 24 hours. When i reset it, it works again for 24 hours.
    I tried several things but i cannot see what i am doing wrong in the code.
    DEVICE 16F628A                ;Gebruik een 16F628A type
    CONFIG HS_OSC, WDT_OFF, PWRTE_ON, LVP_OFF, MCLRE_OFF
    ALL_DIGITAL TRUE              ;Alle ingangen digitaal
    XTAL 20 ;Kristal van 20MHz
     HSERIAL_BAUD = 2400        ' Set baud rate to 2400
     HSERIAL_RCSTA = %10010000  ' Enable serial port and continuous receive
     HSERIAL_TXSTA = %00100000  ' Enable transmit and asynchronous mode
     HSERIAL_CLEAR = ON         ' Optionally clear the buffer before receiving
     PORTB_PULLUPS ON              ;On-chip pull-up weerstanden actief
    ;        76543210
    PORTA = %00000000 ;Alle niveaus van PORTA eerst laag maken
    PORTB = %00000000 ;Alle niveaus van PORTB eerst laag maken
    TRISA = %00000000 ;Alle PORTA poorten omschakelen als ingang
    TRISB = %11111111 ; 1 = Input 0 = Output
     ;Logische constanten
    SYMBOL K1   = PORTA.2
    SYMBOL S1   = PORTB.7
    SYMBOL S2   = PORTB.6
    DIM SerData   AS BYTE
    DIM Opdracht  AS BYTE
    DIM S1_Status AS BIT
    DIM S2_Status AS BIT
    S1_Status = 0
    S2_Status = 0
    CLEAR                         ;Wis alle RAM geheugen
    HSEROUT["Program Started"]
    MainProgram:
    WHILE 1 = 1                   ;Oneindige lus
    IF S1 = 0 THEN                ;S1 is Ingedrukt
        IF S1_Status = 1 THEN
          HSEROUT["11"]
          S1_Status = 0
        IF S1_Status = 0 THEN
          HSEROUT["10"]
          S1_Status = 1
    IF S2 = 0 THEN                ;S1 is gesloten.
        IF S2_Status = 1 THEN
          HSEROUT["21"]
          S2_Status = 0
        IF S2_Status = 0 THEN
            HSEROUT["20"]
            S2_Status = 1
    HSERIN 10, timeout,[DEC SerData]
      SELECT SerData
        CASE 10
          LOW K1
        CASE 11
          HIGH K1
        CASE 12
          HIGH K1
          DELAYMS 50
          LOW K1
      END SELECT
    WEND
    timeout:
    GOTO MainProgram
    END                           ;Einde programma
    Who can help me ?
    Nov 2008
    Default Re: Crashing 16F628 Code
    What compiler are you using? That looks like PDS code.
    This is a Picbasic forum.
    CharlieM
    Using PBP3
    MCSPX
    Nov 2008
    well what meant was that is is a forum for PBP and not PDS.
    CharlieM
    Using PBP3
    MCSPX
    While not PBP, it is similar enough to understand, I would ask 2 questions, what happens to the select case statement if not any of those choices?
    In PBP we have a case else where you can direct what is to happen, does your compiler automatically jump to end select if there is no match, or does it run out into La La Land, stack under / overflow sit and wait for help . . . ?
    The other thing I might try is to enable the WDT.
