4 EEPROM Chips Recording Routine
Results 1 to 8 of 8
    Feb 2005
    Bellevue
    Default 4 EEPROM Chips Recording Routine
    I have a problem with my recording routine. I have 4 x 24LC512 chips in line with an 18F2525. The Chips are:
    Chip1 con %10100000 ' address of chip1
    Chip2 con %10100010 ' address of chip2
    Chip3 con %10100011 ' address of chip3
    Chip4 con %10100001 ' address of chip4
    The problem is this: I record timestamped data to these chips one after the other. These 4 chips together hold 10 minutes of data at a .1 second update rate. I use a 'Chipselect' variable to start with chip1, then move through them all, counting to from 0 to 63872 on each chip (128byte pages) -- the data is mixed up.
    My routine has a debug that shows on a monitor it is writing to chip1, chip2, etc., and shows the memory address. Watching it everything looks fine.
    Then when I play it back, I see some really odd stuff. I'd expect to see is a list of data timestamped starting with Time=0 and ending with time=10.
    What I see is mixed up data. A chip holds about 1500 records. so you'd expect:
    Chip 1 = 0-1500
    Chip2 = 1501=3000
    chip3 = 3001-4500
    chip4 = 4501-6000
    but the time would just jump nicely from chip to chip... It doesn't
    The data is mixed up 1 and 4 and 2 and 3 contain the same data...
    Am I addressing these chips wrong?
    Thanks..
    Did you set correctly A0,A1,A2 of each EEPROM correctly to VCC and GND on your board to match to your defines??? any schematic?
    Feb 2005
    Bellevue
    The eeproms are electrically set as follows:
    A0 A1 A2
    Chip1 - - -
    Chip2 + - -
    Chip3 + + -
    Chip4 - + -
    I have a resistor on SCA/SCL lines (one tho for all lines, not one for each chip.)
    o.k. this is why...
    try those define and post your results
    Chip3 con %10100110 ' address of chip3
    Chip4 con %10100100 ' address of chip4
    Feb 2005
    Bellevue
    Smile Success!
    Yup! that was it.. I was off a position in the setup. THANKS! Oddly it seemed like I was writing to chips 3 and 4 and I must have been writing to both at the same time.
    TG
    hehe, great to know it's working for you now !
    FLAVIO's Avatar
    FLAVIO Guest
    Default Error On Address Chip
    EXAMPLE:
    Chip3 con %10100100 ' address of chip3
    Chip4 con %10100110 ' address of chip4
    By Flavio
    [email protected]
    Talking
    Quote Originally Posted by Flavio
    EXAMPLE:
    By Flavio
    [email protected]
    And the question is.... missing!
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
