interrupt on a port
Results 1 to 3 of 3
    May 2006
    Default interrupt on a port
    HI
    i use 16F877A
    how use interrupt on a port B (other that rb0) with 3 button.
    for interrupt on RB4 to RB7 i must use intcon=00001000?
    and intcon.0=0 to reset flag?
    when i test this code . it dont work!
    code:
    ' On Interrupt - Interrupts in BASIC
    ' Turn LED off on RA1 if Interrupt on PORTB.4
    led var PORTA.1
    trisa=1
    LED=1 'just to see if port RA.1 is ok
    pause 1000 '
    OPTION_REG = $7f ' Enable PORTB pullups
    On Interrupt Goto myint ' Define interrupt handler
    INTCON =%00001000
    loop: High led ' Turn LED on
    Goto loop
    ' Interrupt handler
    Disable ' No interrupts past this point
    myint:
    INTCON.0 = 0 ' Clear interrupt flag
    low led ' If we get here, turn LED off
    Pause 2000 ' Wait .5 seconds
    resume ' Return to main program
    Enable
    with this code : led low and an action on rb4 nop
    sample prog to use a port (other that RB0) and how use choice of different button?
    please thank
    Hi Nick,
    In the Interrupt handler, you need to read PORTB to "end the mismatch".
    Temp = PORTB
    Otherwise, as soon as you RESUME, it will interrupt again.
    May 2006
    Smile interrupt on port RB.4 to RB.7
    HI
    THANKS for your help
    this is my final code
    it s ok and works
    ' On Interrupt RB4 to RB7 - Interrupts in BASIC
    ' Turn LED1 off on RA1 if Interrupt on PORTB.4
    ' Turn LED2 off on RA2 if Interrupt on PORTB.5
    OPTION_REG = %1000000 ' Enable PORTB pull-ups
    ADCON1=6 ' port A = digital
    TRISA=%00000000
    TRISB=%11111111
    PORTA=%11111111
    PORTB=%11111111
    INTCON =%00001000
    loop:
    @nop
    Goto loop
    'interrupt handler
    myint:
    IF PORTB.4=0 THEN goto LEDRTN
    IF PORTB.5=0 THEN GOTO LED1RTN
    LEDRTN: ' port B.4=0
    PORTA.1=0 ' turn LED1 off
    PAUSE 500 ' pause
    PORTA.1=1 ' turn LED1 on
    INTCON.0=0 ' Clear the RB port change flag bit
    LED1RTN: ' port B.5=0
    PORTA.2=0 ' turn LED2 off
    PAUSE 4000 ' pause
    PORTA.2=1 ' turn LED2 on
    Enable
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 14th November 2008, 18:25
  3. How to set TMRO & TMR3 as Counter?.
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 18th May 2007, 09:52
