Sorting arrays
Results 1 to 7 of 7
Thread: Sorting arrays
    Default Sorting arrays
    I am trying to sort paired ADC readings in two arrays. In a loop, an0 an1 are sampled and stored
    in seperate arrays. These become matched pairs for that time period. I need the min/max for all the readings for AN0. No problem with one array. My problem is keeping the AN1 samples, paired with the original AN0 samples after sorting. If anyone has an approach, I would really appreciate
    the help. Thanks
    Example:
    Sampled RAW data
    Array
    Pos AN0 AN1
    1 512 514
    2 512 512
    3 998 326
    4 1021 270
    5 640 499
    6 300 504
    7 423 511
    8 512 512
    9 512 514
    10 510 512
    11 511 512
    12 515 512
    What I need below
    SORTED AN0 IN ASSENDING ORDER, AN1 STAYS PAIRED WITH ORIGINAL AN0
    New Pos AN0 AN1 Old Pos
    1 300 504 6
    2 423 511 7
    3 510 512 10
    4 511 512 11
    5 512 514 1
    6 512 512 2
    7 512 512 8
    8 512 514 9
    9 515 512 12
    10 640 499 5
    11 998 326 3
    12 1021 270 4
    The code below is based on Melanie's, which appeared in post 4 of this thread
    http://www.picbasic.co.uk/forum/showthread.php?t=6734
    I hope this can be modified to do what I need
    SAMPLE_AN0 WORD [12]
    SAMPLE_AN1 WORD [12]
    CounterA var BYTE
    DataTemp var WORD
    Getsamples:
     For A = 1 to 12
      adcin 0 SAMPLE_AN0[A]
      adcin 1 SAMPLE_AN1[A]
     NEXT A
    Sortdata: 'THIS WILL SORT SAMPLES_AN0 not SAMPLE_AN1
    CounterA=0
    SortArrayLoop:
    If SAMP_AN0[CounterA+1] < SAMP_AN0[CounterA] then
        DataTemp = SAMP_AN0[CounterA]
        SAMP_AN0[CounterA] = SAMP_AN0[CounterA+1]
        SAMP_AN0[CounterA+1]= DataTemp
    If CounterA > 0 then CounterA = CounterA - 2
        CounterA = CounterA + 1
    If CounterA < 11 then goto SortArrayLoop
    Last edited by mark_s; - 21st March 2012 at 22:08. Reason: format changed when postedm, sorry
    Default Re: Sorting arrays
    Off the top of my head again, what if you concatenate the numbers?
    510512
    511512
    No matter what you have in the last 3 positions, 510 will always be in front of 511.
    Maybe for every entry have an array of 4 words?
    Sorting based on the second element of the array.
    Thanks for the feedback.
    Demon, not sure I follow your idea?
    Ioannis, I think this is the way. An array of arrays.
    Are you suggesting a 4 word array as a Long variable?
    Every data base or logger must deal with this problem. So I'm sure there
    is a standard way. Most examples show the data being processed in a
    pc using excel or VB and not in a pic.
    Thanks again
    As you move the AN0 samples, move the AN1 samples the same way...
    CounterA var BYTE
    DataTemp var WORD
    Getsamples:
     For A = 1 to 12
     NEXT A
    CounterA=0
    SortArrayLoop:
        DataTemp = SAMP_AN1[CounterA]
        SAMP_AN1[CounterA] = SAMP_AN1[CounterA+1]
        SAMP_AN1[CounterA+1]= DataTemp
    Darrel,
    Thank you for the answer!
    As Darrel replied, there is no need for a long variable. Besides you have 4 discrete variable that you have to treat as a whole.
