SERIN2 = ok, HSERIN = no!
Results 1 to 29 of 29
    Default Re: SERIN2 = ok, HSERIN = no!
    EDIT: Your baud looks good.
    At first I didn't see your BRG16 =1, but Steves Picmulticalc is still good. I'll see if I can find anything real
    Steves PicMultiCalc tool works great for this, and give you text results you can just paste in to your code. Just enter OSC speed, baudrate, and press the go button.
    DEFINE HSER_SPBRG 12 ' 9600 Baud @ 8MHz, 0.16%
    http://www.picbasic.co.uk/forum/cont....-PICMultiCalc
    http://www.scalerobotics.com
    SWITZERLAND (french speaking)
    ... I used PICMulticalc and pasted its results in my first post's HSERIN code; unfortunately it doesn't work.
    Roger
    Could it be hardware related? Pull-up or current-limitting resistors?
    What about the Mode setting (True VS Inverted)?
    EDIT: You use Open,True,N,9600bps for SERIN, that's inverted.
    You use BAUDCON = %01001000 for HSERIN, bit 5, 0 = non-inverted Data/Receive Polarity.
    There could be other stuff, but that's all I got.
    Hi Demon,
    I tried all that already. Neither a new chip nor data polarity will change anything; HSERIN won't work...while SERIN2 does :-/
    Roger
    BAUDCON bit 3
    BRG16: 16-Bit Baud Rate Register Enable bit
    1 = 16-bit Baud Rate Generator – SPBRGH and SPBRG
    0 = 8-bit Baud Rate Generator – SPBRG only (Compatible mode), SPBRGH value ignored
    Don't you want 8-bit?
    Last edited by Demon; - 20th March 2012 at 15:27. Reason: Removed unnecessary stuff
    I tried BAUDCON = %10000000 if this is what you mean. No luck either.
    Roger
