Hserin/hserout ?
Results 1 to 7 of 7
    Scott's Avatar
    Scott Guest
    Default Hserin/hserout ?
    What is wrong with the following code?
    HSEROUT ["AT+CGDCONT=1", 34, "IP", 34, ",", 34, "myserver.address", 34,13,10,13,10,13,10] ' 34 is for "
    HSERIN 5000, setup, [WAIT("OK")]
    I am able to check the device I am communicating with using HyperTerminal. I am able to get the CONNECT back from the device.
    I am using a PIC16F876A with an RS-232 driver. PORTC.6 is my TX and PORTC.7 is my RX.
    Thanks for your help,
    Scott
    Quote Originally Posted by Scott
    Since it looks like you're able to do everything... what's the problem?
    are you really use Hyperterminal? OH MY GOD another victim of this crap software!
    have you try with MicroCode Studio in the serial communication window?
    Scott's Avatar
    Scott Guest
    I have this working with another board using Serin/Serout no problem. Once I tried my new hardware that is setup with the USART pins C6 and C7 it does not work. My hardware has a DB15HD that is to connect to my modem I cannot connect directly to my PC.
    Another question: Can I use Serin/Serout and not Hserin/Hserout on the USART pins C6 and C7?
    I use hyperterminal to debug the modem not my hardware.
    for sure you can use serin/serout on those pins. But if you send us your code or a snip with your DEFINE, TRIS and others, we can help you to make it work
    Scott's Avatar
    Scott Guest
    Here is some of my code:
    ' Setup Crystal Frequency in mHz
    DEFINE OSC 20 ' Set Xtal Frequency
    ' Setup Auto Epic Settings
    @ DEVICE PIC16F876A
    @ DEVICE HS_OSC ' System Clock Options
    @ DEVICE WDT_OFF ' Watchdog Timer
    @ DEVICE PWRT_OFF ' Power-On Timer
    @ DEVICE BOD_OFF ' Brown-Out Detect
    @ DEVICE LVP_OFF ' Low-Voltage Programming
    @ DEVICE CPD_OFF ' Data Memory Code Protect
    @ DEVICE PROTECT_OFF ' Program Code Protection
    ' Setup Hardware for uart
    DEFINE HSER_BAUD 9600
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 129
    DEFINE HSER_CLROERR 1 ' automatic clear the overflow
    TRISC.6 = 0
    TRISC.7 = 1
    ipaddress var byte[15]
    'Setup Modem for No Flow Control
    hserout ["at+ifc=0,0", 13]
    checkip:
    hserout ["at*e2ipi=0", 13] ' Check the IP Session
    hserin 20000, setup, [WAIT("*E2IPI: "),STR ipaddress]
    Hserout ["at+cgdcont=1,", 34, "IP", 34, ",", 34, "myserver.address", 34,13]
    Hserin 20000, setup, [WAIT("OK")]
    Hserout ["at*e2ipa=1,1", 13]
    I have been able to connect my board to my pc and the hserout is working as it should. I am not able to get anything back from the pc or modem.
    Is the hserin setup correctly?
    Thanks again, Scott
    mmm. Actually you don't need this DEFINE HSER_BAUD since DEFINE HSER_SPBRG do the same job but i don't think it's the problem source.
    What about if you remove the timeout label?
    Did you try Hyperterm or else to send the expected string to the PIC?
  1. Help understanding HSERIN/HSEROUT
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2021, 08:47
  2. Rs485 Using Hserin/hserout
    Last Post: - 31st January 2008, 10:42
  3. Hserin/Hserout question
    By Philley in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 14:17
  4. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2006, 00:07
  5. Replies: 1
    Last Post: - 16th June 2005, 03:56
