Measuring pulse width using ccp
Results 1 to 7 of 7
    Feb 2012
    Default Measuring pulse width using ccp
    HELLO ALL
    I FOUND PICBASIC PRO CODE MADE BY BRUCE(ON 20th July 2006, 07:45) FOR 18F242 TO MEASURE PW USING CCP HARDWARE. I FOUND THAT IS VERY SHORT AND,NEAT AND STRAIGHT FORWARD. I HAVE 16F877A AND I WANT TO MAKE A CAP METER. I HAVE WRITTEN CODE BASED ON BRUCE'S CODE BUT USING 16F877A. I TRIED TO SIMULATE THIS ON PROTEUS . IT NEVER WORKED. BUT BRUCE'S CODE WORK FINE FOR 18F242. I DID EVERY THING POSSIBLE TO GET IT WORKING BUT NO LUCK. I AM POSTING THIS COD FOR SOME BODY OR BRUCE TO HELP ME PLEASE ON THIS.IT LOOKED TO ME OBSCURE NO MORE I CAN DO.COD:
    'PIC16F877A
    DEFINE OSC 20
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    Low PORTE.2
    PIE1.2=1
    Symbol Capture = PIR1.2 ' CCP1 capture flag
    T1 VAR WORD ' 1st capture value
    PW VAR WORD ' 2nd capture value & ultimately final pulse width
    TRISC.2 = 1 ' CCP1 input pin (Capture input)
    INTCON = 0 ' Interrupts off
    ReLoad:
    CCP1CON = %00000101 ' Capture mode, 4capture on rising edge
    T1CON = 0 ' TMR1 prescale=1, clock=Fosc/4, TMR1=off (200nS per count @20MHz)
    TMR1H = 0 ' Clear high byte of TMR1 counter
    TMR1L = 0 ' Clear low byte
    T1CON.0 = 1 ' Turn TMR1 on here
    Capture = 0 ' Clear capture int flag bit
    While !Capture ' Wait here until capture on rising edge
    Wend
    ' Rising edge detected / stuff Timer1 value in T1
    T1.HighByte = CCPR1H
    T1.LowByte = CCPR1L
    CCP1CON = %00000100 ' Configure capture for falling edge now
    Capture = 0 ' Clear capture interrupt flag bit
    While !Capture ' While here until capture on falling edge
    Wend
    ' Falling edge detected / stuff Timer1 value in PW
    PW.HighByte = CCPR1H
    PW.LowByte = CCPR1L
    PW = PW-T1 ' High pulse width = PW-T1
    ' Convert to uS for 20MHz osc with 200nS Timer1 ticks
    PW = (PW * 2)/10
    Pause 150 ' Pause to let LCD power up
    LCDOut $fe,1, "PULSE WIDTH" ' Display if C1OUT = 1
    LCDOut $fe,$C0, #PW
    GOTO ReLoad
    OBAID
    Feb 2012
    Default Re: Measuring pulse width using ccp
    It is sad that we are posting in picbasic pro forum ,you can see many people viwed your post, they just pass by, they do'nt offer any help.i am certain that among them some who know the answer
    The one big thing you need to watch out for when moving code from one PIC to another is how the registers are configured. You need to go line by line and look up registers. For example, maybe timer1 one is associated with CCP2 on one chip and CCP1 with another. That is just purely an example but things like that are common. It might be the smallest difference from one PIC to another that will prevent code from working on one and not the other.
    Quote Originally Posted by abofar View Post
    You have to realize that there are a LOT of novice members here. Just because they don't post does not mean they are ignoring you. Many read threads because they have similar questions, or like me, just want to see if they can learn something new.
    I've used PICs since 2004 and have never touched PWM in a serious way.
    EDIT: you can start by making sure your PIC is configured properly, this is just an example from 16F886:
     __CONFIG _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF &
    _INTRC_OSC_NOCLKOUT
     __CONFIG _CONFIG2, _WRT_OFF & _BOR21V
    http://www.picbasic.co.uk/forum/show...132#post110132
    Have you done much searching for CCP and PWM?
    boffin2's Avatar
    boffin2 Guest
    I don't know if you eventually solved this problem but I think you may be using the wrong interrupt commands. For CCP you need to use CCP1IF interrupt flag and CCP1IE to enable/disable the interrupt. Do not use timer interrupts. The Microchip data sheet "Tips 'n Tricks" DS41214A page 8 explains how to measure pulse width. I have tried it and it does work!
    Feb 2012
    Hi
    Thank you for asking, problem is solved.Problem was that simulator is too slow.
    Thanks again
    Obaid
