Hi, Charles
just a little error I Can't explain ...
Compiles ( and runs in real life ... ) fine with MPLAB 8.84, but doesn't want to compile with MPLABX ...
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
make -f nbproject/Makefile-default.mk dist/default/production/Train_Rentrant.X.production.hex
make[2]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
gnumkdir -p build/default/production
"C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p16f628 Train_R.pbp
Error[113] C:\PBP3\PBPPIC14.LIB 451 : Symbol not previously defined (TMR1)
Error[113] C:\PBP3\PBPPIC14.LIB 465 : Symbol not previously defined (TMR1)
Error[113] C:\PBP3\PBPPIC14.LIB 479 : Symbol not previously defined (TMR1)
looks a definition for TMR1 ( as a word ) is missing somewhere ... but where ???
Here is the program
AlainCode:'**************************************************************** '* Name : Train_Rentrant '* Author : Alain '* Notice : Copyright (c) 2010 '* : All Rights Reserved '* Date : 9 avr. 2012 '* Version : 1.0 '* Processor : '* Notes : Gestion de train rentrant électrique '* : '**************************************************************** '****************************************************************************** 'Configuration '****************************************************************************** #CONFIG __CONFIG _BODEN_ON &_CP_OFF & _PWRTE_ON & _WDT_ON & _LVP_OFF & _MCLRE_ON & _XT_OSC #ENDCONFIG '****************************************************************************** 'Config Timer 1 T1CON = 110100 ' 1/8, internal osc,stopped INTCON = 000000 PIE1 = 000001 PIR1 = 0 TMR1 = 0 '****************************************************************************** 'Definitions '****************************************************************************** DEFINE PULSIN_MAX 2500 DEFINE BUTTON_PAUSE 255 '****************************************************************************** 'Definitions '****************************************************************************** Temp var Word Servoval var Word mesure var Byte meanval var Byte dureeprog var Byte Pos1 var Byte Pos2 var Byte Timecounter var Byte echantil var Byte delay var Byte side var byte Timeout var Byte CLEAR '****************************************************************************** ' I/Os '****************************************************************************** Sorti var PORTA.0 ' Closed = GND Rentre var PORTA.1 ' Closed = GND LedA var PORTA.2 LedB var PORTA.3 prog var PORTB.0 ' jp2 reglage enclenchement Signal var PORTB.1 ' Entrée Signal Boost var PORTB.3 ' Sortie PWM T2 var PORTB.4 T3 var PORTB.5 T8 var PORTB.6 T5 var PORTB.7 '****************************************************************************** 'Initialisation des ports '****************************************************************************** CMCON = 7 ' All digital PORTA = 0 PORTB = 000000 TRISA = 000011 TRISB = 000011 Neutre CON 150 Traveltime CON 50 DATA @1,180,170,130,1 ' Protection 1ère utilisation '****************************************************************************** 'Lecture des valeurs en EEPROM '****************************************************************************** READ 1, Dureeprog, Pos1, Pos2, Side IF dureeprog <> 255 THEN start '****************************************************************************** 'Mesure de l'impulsion d'enclenchement '****************************************************************************** mesurepro: dureeprog = 255 LOW LedA LOW LedB mesurep: LedA = 0 ' Led Verte LedB = 1 FOR echantil = 1 to 50 PULSIN Signal,1,mesure IF ( mesure < 75) OR ( mesure > 220 ) THEN GOTO mesurep ENDIF IF dureeprog = 255 THEN valable ' Stability check IF ( mesure < ( dureeprog - 1 )) OR ( mesure > ( dureeprog + 1 )) THEN GOTO mesurep ENDIF ' Valid mesure valable: dureeprog = mesure NEXT echantil LedB = 0 delay = 0 BUTTON prog,0,255,0,delay,1,mesurepro 'Enlever le cavalier '****************************************************************************** ' Calcul Pos1, Pos2 '****************************************************************************** SELECT CASE Dureeprog CASE is => ( Neutre + 20 ) Pos1 = ( Dureeprog - 10 ) Temp = 2*Neutre - Pos1 Pos2 = Temp Side = 1 CASE is < ( neutre - 20 ) Pos1 = ( Dureeprog + 10 ) Temp = 2*Neutre - Pos1 Pos2 = Temp Side = 0 CASE ELSE IF Dureeprog => Neutre THEN Pos1 = Neutre + 10 Pos2 = Neutre - 10 Side = 1 ELSE Pos1 = Neutre - 10 Pos2 = Neutre + 10 Side = 0 ENDIF END SELECT WRITE 2,Pos1, Pos2, Side ' Save Switching Positions '****************************************************************************** '****************************************************************************** start: '****************************************************************************** IF Timeout THEN ' Locking for Timeout GOTO NoSignal ENDIF Servoval = 0 FOR Echantil = 1 to 5 ' Check 5 cycles and take mean value PULSIN Signal,1,mesure IF ( mesure < 75) OR ( mesure > 220 ) THEN GOTO NoSignal ENDIF IF Meanval = 0 THEN Valable1 ' Stability check IF ( mesure < ( meanval - 2 )) OR ( mesure > ( meanval + 2 )) THEN GOTO start ' Reset cycle ENDIF Valable1: Servoval = Servoval + mesure NEXT echantil Meanval = Servoval/5 '****************************************************************************** ' IF Side THEN SELECT CASE Meanval CASE is => pos1 'IF T2CON.2 = 0 THEN HPWM 1,127,20000 GOTO UP ' _________________ Gear UP CASE is < pos2 'IF T2CON.2 = 0 THEN HPWM 1,127,20000 GOTO DOWN '__________________ Gear DOWN CASE Else 'IF T2CON.2 = 1 THEN HPWM 1,0,20000 GOTO NoMove ' _________________ Gear LOCKED END SELECT ELSE SELECT CASE Meanval CASE is <= pos1 'IF T2CON.2 = 0 THEN HPWM 1,127,20000 GOTO UP ' _________________ Gear UP CASE is > pos2 'IF T2CON.2 = 0 THEN HPWM 1,127,20000 GOTO DOWN '__________________ Gear DOWN CASE Else 'IF T2CON.2 = 1 THEN HPWM 1,0,20000 GOTO NoMove ' _________________ Gear LOCKED END SELECT ENDIF '***************************************************************************** UP: '***************************************************************************** IF Rentre = 0 OR Timeout THEN ' Verification fins de course T1CON.0 = 0 ' Stop the timer TMR1.0 = 0 ' Reset the timer LedA = 1 ' Solid GREEN Led LedB = 0 GOTO NOMOVE ENDIF T1CON.0 = 1 LOW T8 ' T8 + T3 OFF LOW T3 PAUSEUS 100 HIGH T5 ' T5 + T2 ON HIGH T2 LedA = 0 IF PIR1.0 THEN LedB = ~ LedB TMR1 = 0 TimeCounter = Timecounter + 1 IF Rentre THEN IF timecounter => TravelTime THEN Timeout = 1 GOSUB NoMove ENDIF ELSE GOSUB NoMove ENDIF ENDIF TMR1.0 = 1 PIR1.0 = 0 ' Clear Flag GOTO Start '***************************************************************************** DOWN: '***************************************************************************** IF Sorti = 0 OR Timeout THEN ' Verification fins de course T1CON.0 = 0 ' Stop the timer TMR1.0 = 0 ' Reset the timer LedA = 0 ' Solid RED Led LedB = 1 GOTO NOMOVE ENDIF T1CON.0 = 1 LOW T5 ' T5 + T2 OFF LOW T2 PAUSEUS 100 HIGH T8 ' T8 + T3 ON HIGH T3 IF PIR1.0 THEN LedA = ~ LedA TMR1 = 0 TimeCounter = Timecounter + 1 IF Sorti THEN IF timecounter => TravelTime THEN Timeout = 1 GOTO NoMove ENDIF ELSE GOTO NoMove ENDIF ENDIF LedB = 0 T1CON.0 = 1 PIR1.0 = 0 ' Clear Flag GOTO Start '***************************************************************************** NOMOVE: ' Bridge switched OFF , Led Remains unchanged '***************************************************************************** 'Brake a While LOW T5 ' Hi part of Bridge OFF LOW T8 Pauseus 100 HIGH T2 ' Low part of Bridge ON HIGH T3 PAUSE 500 ' LOW T5 ' Hi Bridge OFF ' LOW T8 LOW T2 ' Low Bridge OFF LOW T3 GOTO Start '***************************************************************************** NoSignal: '***************************************************************************** IF PIR1.0 THEN LedA = ~ LedA TMR1 = 40536 ' Quick 5Hz RED Flash PIR1.0 = 0 ' Clear Flag ENDIF LedB = 0 T1CON.0 = 1 GOTO Start '***************************************************************************** '***************************************************************************** END
