pbp 3 and MPLAB X
Results 1 to 34 of 34
    Sep 2007
    Default Re: pbp 3 and MPLAB X
    I've updated the plugin download.
    http://pbp3.com/downloads/com-melabs-pbptoolchain.zip
    Let me know what you find.
    I tested with a PICkit3. Source-level debugging works and it will show PBP variables in the watch window.
    MPLABX still seems a bit spotty for debugging. I'm hoping for some improvement in version 1.20.
    Charles Leo
    microEngineering Labs, Inc.
    http://melabs.com
    Italy
    Hi Charles,
    I still have to understand how MPLABX works, but I can confirm that with the udated plugin I no longer have that java error after build.
    I'll come back here again next week. For the moment, many thanks.
    Marco
    Mar 2012
    Quote Originally Posted by Charles_Leo View Post
    Thank you, Charles
    No errors with new plugin.
    Fabio
    Nov 2009
    Virginia, USA
    Works like a charm for me also. Thanks !
    Gary-W4GNS
    MicroCode Studio Plus 5.0.0.2 MCSPX
    PBP 3.0 Gold Edition 3.0.5.4
    Tickled Speechless using PBP 3.0
    Hi, SupaCharles
    Works fine here :
    CLEAN SUCCESSFUL (total time: 62ms)
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    make -f nbproject/Makefile-default.mk dist/default/production/Servotest.X.production.hex
    make[2]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    gnumkdir -p build/default/production
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p16f887 Servotes.pbp
    PICBASIC PRO(TM) Compiler 3.0.5.4, (c) 1998, 2012 microEngineering Labs, Inc.
    All Rights Reserved.
    gnumkdir -p dist/default/production
    cp Servotes.HEX dist/default/production/Servotest.X.production.hex
    cp Servotes.COF dist/default/production/Servotest.X.production.cof
    rm -f Servotes.COF
    make[2]: Leaving directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    make[1]: Leaving directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    BUILD SUCCESSFUL (total time: 3s)
    Loading C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X/dist/default/production/Servotest.X.production.hex...
    Loading C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X/dist/default/production/Servotest.X.production.cof...
    Loading completed
    lots of thanks to you once more ...
    Hi, Charles
    just a little error I Can't explain ...
    make[1]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
    make -f nbproject/Makefile-default.mk dist/default/production/Train_Rentrant.X.production.hex
    make[2]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p16f628 Train_R.pbp
    Error[113] C:\PBP3\PBPPIC14.LIB 451 : Symbol not previously defined (TMR1)
    Error[113] C:\PBP3\PBPPIC14.LIB 465 : Symbol not previously defined (TMR1)
    Error[113] C:\PBP3\PBPPIC14.LIB 479 : Symbol not previously defined (TMR1)
    Compiles ( and runs in real life ... ) fine with MPLAB 8.84, but doesn't want to compile with MPLABX ...
    looks a definition for TMR1 ( as a word ) is missing somewhere ... but where ???
    Here is the program
    '*  Name      : Train_Rentrant
    '*  Author    : Alain
    '*  Notice    : Copyright (c) 2010
    '*            : All Rights Reserved
    '*  Date      : 9 avr. 2012
    '*  Version   : 1.0
    '*  Processor :
    '*  Notes     : Gestion de train rentrant électrique
    'Configuration
        __CONFIG  _BODEN_ON &_CP_OFF & _PWRTE_ON & _WDT_ON & _LVP_OFF & _MCLRE_ON  & _XT_OSC
    'Config Timer 1
    T1CON  = 110100     ' 1/8, internal osc,stopped
    INTCON = 000000
    PIE1 = 000001
    PIR1 = 0
    TMR1 = 0
    'Definitions
    DEFINE PULSIN_MAX 2500
    DEFINE BUTTON_PAUSE 255
    'Definitions
     Temp  var Word
     Servoval var Word
     mesure      var Byte
     meanval     var Byte
     dureeprog   var Byte
     Pos1  var Byte
     Pos2  var Byte
     Timecounter var Byte
     echantil    var Byte
     delay  var Byte
     side        var byte
     Timeout  var Byte
     CLEAR
    ' I/Os
     Sorti       var PORTA.0 ' Closed = GND
     Rentre  var PORTA.1 ' Closed = GND
     LedA  var PORTA.2
     LedB        var PORTA.3
     prog       var PORTB.0 ' jp2 reglage enclenchement
     Signal  var PORTB.1 ' Entrée Signal
     Boost  var PORTB.3 ' Sortie PWM
     T2   var PORTB.4
     T3   var PORTB.5
     T8   var PORTB.6
     T5   var PORTB.7
    'Initialisation des ports
     CMCON  = 7    ' All digital
     PORTA   = 0
     PORTB   = 000000
     TRISA  = 000011
     TRISB  = 000011
     Neutre   CON 150
     Traveltime  CON 50
     DATA @1,180,170,130,1   ' Protection 1ère utilisation
    'Lecture des valeurs en EEPROM
     READ 1, Dureeprog, Pos1, Pos2, Side
     IF dureeprog <> 255 THEN start
    'Mesure de l'impulsion d'enclenchement
    mesurepro:
     dureeprog = 255
     LOW LedA
     LOW LedB
    mesurep:
     LedA  = 0   ' Led Verte
     LedB  = 1
     FOR echantil = 1 to 50
     PULSIN Signal,1,mesure
     IF ( mesure < 75) OR ( mesure > 220 ) THEN
      GOTO mesurep
     IF dureeprog = 255 THEN valable
    ' Stability check
     IF ( mesure < ( dureeprog - 1 )) OR ( mesure > ( dureeprog + 1 )) THEN
      GOTO mesurep
    ' Valid mesure
    valable:
     dureeprog = mesure
     NEXT echantil
     LedB  = 0
     delay  = 0
     BUTTON prog,0,255,0,delay,1,mesurepro 'Enlever le cavalier
    ' Calcul Pos1, Pos2
     SELECT CASE Dureeprog
      CASE is => ( Neutre + 20 )
       Pos1  = ( Dureeprog - 10 )
       Temp  = 2*Neutre - Pos1
       Pos2  = Temp
       Side = 1
      CASE is < ( neutre - 20 )
       Pos1  = ( Dureeprog + 10 )
       Pos2  = Temp
       Side = 0
      CASE ELSE
        IF Dureeprog => Neutre THEN
         Pos1 = Neutre + 10
         Pos2 = Neutre - 10
         Side = 1
         Pos1 = Neutre - 10
         Pos2 = Neutre + 10
         Side = 0
     END SELECT
     WRITE 2,Pos1, Pos2, Side    ' Save Switching Positions
    start:
     IF Timeout THEN      ' Locking for Timeout
      GOTO NoSignal
     Servoval = 0
     FOR Echantil = 1 to 5     ' Check 5 cycles and take mean value
        GOTO  NoSignal
      IF Meanval = 0 THEN Valable1
     ' Stability check
      IF ( mesure < ( meanval - 2 )) OR ( mesure > ( meanval + 2 )) THEN
       GOTO start    ' Reset cycle
     Valable1:
      Servoval = Servoval + mesure
      NEXT echantil
     Meanval = Servoval/5
     IF Side THEN
      SELECT CASE Meanval
       CASE is => pos1
        'IF T2CON.2 = 0 THEN HPWM 1,127,20000
        GOTO UP       ' _________________  Gear UP
       CASE is <  pos2
        GOTO DOWN      '__________________  Gear DOWN
       CASE Else
        'IF T2CON.2 = 1   THEN HPWM 1,0,20000
        GOTO NoMove      ' _________________  Gear LOCKED
      END SELECT
      SELECT CASE Meanval
       CASE is <= pos1
       CASE is >  pos2
       CASE Else
      END SELECT
    UP:
     IF Rentre = 0 OR Timeout THEN ' Verification fins de course
      T1CON.0 = 0    ' Stop the timer
      TMR1.0 = 0    ' Reset the timer
      LedA = 1    ' Solid GREEN Led
      LedB = 0
      GOTO NOMOVE
     T1CON.0  = 1
     LOW  T8     ' T8 + T3 OFF
     LOW  T3
     PAUSEUS 100
     HIGH  T5     ' T5 + T2 ON
     HIGH  T2
     LedA  = 0
     IF PIR1.0 THEN
       LedB = ~ LedB
      TMR1 = 0
      TimeCounter = Timecounter + 1
      IF Rentre THEN
       IF timecounter => TravelTime THEN
           Timeout = 1
        GOSUB NoMove
       GOSUB NoMove
     TMR1.0  = 1
     PIR1.0  = 0      ' Clear Flag
     GOTO Start
    DOWN:
     IF Sorti = 0 OR Timeout THEN   ' Verification fins de course
      LedA = 0    ' Solid RED Led
      LedB = 1
      GOTO NOMOVE
     T1CON.0 = 1
     LOW  T5     ' T5 + T2 OFF
     LOW  T2
     PAUSEUS 100
     HIGH  T8     ' T8 + T3 ON
     HIGH  T3
     IF PIR1.0 THEN
      LedA  = ~ LedA
      TMR1  = 0
       IF Sorti THEN
         Timeout = 1
         GOTO NoMove
        GOTO NoMove
     LedB   = 0
     T1CON.0  = 1
     GOTO Start
    NOMOVE: ' Bridge switched OFF , Led Remains unchanged
     'Brake a While
     LOW  T5     ' Hi part of Bridge OFF
     LOW  T8
     Pauseus 100
     HIGH T2     ' Low part of Bridge ON
     HIGH  T3
     PAUSE 500
    ' LOW  T5     ' Hi Bridge OFF
    ' LOW  T8
     LOW  T2     ' Low Bridge OFF
     LOW  T3
     GOTO Start
    NoSignal:
     IF PIR1.0 THEN
      LedA = ~ LedA
      TMR1 = 40536    ' Quick 5Hz RED Flash
     LedB  = 0
     T1CON.0  = 1
     GOTO Start
    The 16F628.inc file for MPASMX doesn't have an EQU for TMR1.
    The 16F628.inc file for MPASM in MPLAB 8 does have TMR1.
    You can add this to your program for a workaround ...
        ifndef TMR1
    TMR1 = TMR1L
    Hi, Darrel
    Thanks for the tip.
    I finally have modified the Mpasmx .inc file ...
    With PBP3 there is no more need to modify the PBP . inc files .... but the Mpasmx have to be now ....
    You right : customers ALWAYS complain !!!
