pbp 3 and MPLAB X
Results 1 to 34 of 34
    Italy
    Default pbp 3 and MPLAB X
    Anybody has success in setup MPLAB-X, ICD3 and Picbasic3 ?
    Actually I'm able to write a simple program, build but then an error
    BUILD SUCCESSFUL (total time: 2s)
    Loading C:/Users/Marco/Desktop/Nuova cartella/prova.X/dist/default/production/prova.X.production.cof...
    Loading C:/Users/Marco/Desktop/Nuova cartella/prova.X/dist/default/production/prova.X.production....
    The program file could not be loaded: java.lang.NullPointerException
    ICD3 works fine with MPLAB 8
    Marco
    Default Re: pbp 3 and MPLAB X
    My theory is keep it simple. So I use what Melabs gives with PBP3, the MCSX. When I was using ICD3 as a programmer, I just loaded the hex file in MPLAB8.xx and programed the chip.
    Now I find Pickit2 or 3 much more easy to use, specially with the stand alone program.
    Out of curiosity, I wonder what MPLABX can offer more as na IDE. Please elaborate on this if you have the time.
    Italy
    well, because I have these three products, I just want to know if they must work or if actually there are a lot of compatibility problems.
    PBP3 says it works with MPLABX
    MPLABX says it works with ICD3
    These three parts works togheter or not ?
    Marco
    Marcick,
    I'm afraid I can't help much. I tried to get PBP3 integrated in MPLABX but couldn't even manage to get that working. But anyway, have you seen this page? There's a topic about installing the ICD3. Unfortunately the page doesn't exist but perhaps you can find some other pointers as to where the problem might be.
    Ioannis,
    Well, compared to MCSX, here are three things that I personally would like to have (and that MPLABX offers).
    * Source level debugging
    * Code folding
    * Version control
    But, as I said, I couldn't even manage to integrate PBP into the thing so until someone more intelligent than me writes a step by step guide I'll stick with MCSX.
    Source level debuging would be nice, but is it valid for a higher level lanquage like PBP or is it possible only for ASM or C?
    If this works for PBP, I want it and may do the experiments
    PBP source level debugging works with MPLAB 8 so it should work with MPLABX as well.
    Henrik, I think you are refering to an example of Bruce about this?
    I am trying to locate this. Any help appreciated.
    Marcick, that's a pretty long folder path. It could be complaining about that. I think I had some problems when my folders were that long, so I made them shorter.
    I followed the instructions here: http://support.melabs.com/threads/91-Mplab-X
    But I did have a heck of a time. I tried it on two separate computers, and it seemed to me that on both of them I needed to install the PBP2.60 plugin first (don't ask me why that helped) first, to get PBP3 to work.
    Here are some pictures of the settings I currently have, and a screen shot of code stepping PBP3 in MPLABX.
    http://www.scalerobotics.com
    Italy
    Thanks to everybody,
    now that I see it must work, I'll stuck my head til it worsk for me too ...
    After try and try now I have a different error:
    ERROR: Unable to find proper .org_n section in file C:\Pbpx\prova.X\pippo.O
    Error processing COFF file C:\Pbpx\prova.X\pippo.O
    make[2]: *** [build/default/production/pippo\.cof] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    make[2]: Leaving directory `C:/Pbpx/prova.X'
    make[1]: Leaving directory `C:/Pbpx/prova.X'
    How to install the PBP2.60 plugin also now that I have 3 ?
    Italy
    Sorry, I correct my previous post:
    I can build with success a simple program, but then the error is the same:
    Loading C:/Pbpx/prova.X/dist/default/production/prova.X.production.cof...
    Loading C:/Pbpx/prova.X/dist/default/production/prova.X.production....
    Could it be a problem with long file destination again?
    All is not exactly rosy over here either.
    I do get a file not found error, after I successfully compile. Which I notice is slightly different than you. Are you using the new MPLAB X 1.0 (first non beta)?
    I can run through with the simulator, I can create hex files that I tested to make sure they really worked. But in my testing of MPLAB X, I can't seem to program the devices directly from MPLAB X when using PBP3. For C, the programmers all work, ICD3, Pickit3. I notice in MPLAB X PBP3, the .cof file is put in \dist\default\production file of the project, but the hex is left in the base file of the project. This is not how it works in MPLAB X C. The hex file and the cof file would be found in the \dist\default\production file for C. So I am wondering if the error I am getting is the rest of MPLAB not finding the hex where it thought it would be. This leads me to wonder if the plugin is set right? This doesn't look like any settings I can select, as far as I can tell. I will ask Charles Leo on the MeLabs site, and pass the answer here when he responds.
    Here is a my compiling message:
    CLEAN SUCCESSFUL (total time: 101ms)
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory `C:/local/new/altimeter.X'
    make -f nbproject/Makefile-default.mk dist/default/production/altimeter.X.production.cof
    make[2]: Entering directory `C:/local/new/altimeter.X'
    gnumkdir -p build/default/production
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p12f683 alt-683.pbp
    PICBASIC PRO(TM) Compiler 3.0.4.4, (c) 1998, 2011 microEngineering Labs, Inc.
    All Rights Reserved.
    gnumkdir -p dist/default/production
    cp alt-683.COF dist/default/production/altimeter.X.production.cof
    rm -f alt-683.COF
    make[2]: Leaving directory `C:/local/new/altimeter.X'
    make[1]: Leaving directory `C:/local/new/altimeter.X'
    BUILD SUCCESSFUL (total time: 3s)
    Loading C:/local/new/altimeter.X/dist/default/production/altimeter.X.production.cof...
    The program file could not be loaded: File not found.
    Italy
    Thank you guys,
    Yes, I'm using MPLAB X 1.10, the version actually available for download.
    I don't think it's a problem of long paths. I've choosen c:\pbpx for my development and the other subpath are choosen from MPLAB. I can't do anything else to make the path shorter ...
    Hope Charles will solve everything ...
    Marco
    Ok, I uninstalled MPLAB X 1.00 (required for "upgrade") and installed MPLAB X v1.10, I was asked during install if I wanted to use the old settings, I selected yes.
    Now I get no errors after build, and my .hex file ends up in the correct spot. Seems to me, this is something corrected in MPLAB X v1.10
    Now I am able to get the Pickit3 to program my project from MPLAB X v1.10. Yay!
    I am now wondering if your errors could be a Java problem, with incorrect version. What do you get when you click on help, and info?
    Here is mine:
    Results:
    make -f nbproject/Makefile-default.mk dist/default/production/altimeter.X.production.hex
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -p12f683 alt-683.pbp
    cp alt-683.HEX dist/default/production/altimeter.X.production.hex
    rm -f alt-683.COF
    BUILD SUCCESSFUL (total time: 4s)
    Loading C:/local/new/altimeter.X/dist/default/production/altimeter.X.production.hex...
    Loading completed
    Italy
    wow, happy for you ...
    My java version results 1.6.0_31 that seems newer than yours.
    Sep 2007
    After updating all of my software, I have the same problem as Marcick. I've been in touch with Microchip and I'm told that the hex file handling needs to be updated in our plugin. I hope to have a new plugin packaged with MPLABX 1.20.
    I'm still a bit confused as to why some installations work and some don't.
    Charles Leo
    http://melabs.com
    Very interesting. Thanks Charles for looking in to it, and trying to update the plugin for the next MPLAB X release!
    It worked on both Windows 7 professional 32 bit, and Windows 7 professional 64 bit here.
    On the 32 bit, my info seems to be the same as Marcick's execpt for I have
    Java 1.6.0_26, and he has 1.6.0_31
    java hotspot 20.1-b02 , and he has 20.6-b01:
    I may try updating my Java and see if it breaks my setup, or try a fresh install on a different computer. Will let you know what I find.
    Italy
    no news ?
    marco
    using Win SP3 Home / I7 2600K ... and a Pickit2.
    of course everything ( java, pbp, etc ... ) up to date ...
    make[1]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    make -f nbproject/Makefile-default.mk dist/default/production/Servotest.X.production.cof
    make[2]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p16f887 Servotes.pbp
    PICBASIC PRO(TM) Compiler 3.0.5.4, (c) 1998, 2012 microEngineering Labs, Inc.
    cp Servotes.COF dist/default/production/Servotest.X.production.cof
    rm -f Servotes.COF
    make[2]: Leaving directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    make[1]: Leaving directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X'
    Loading C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X/dist/default/production/Servotest.X.production.cof...
    Loading C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X/dist/default/production/Servotest.X.production....
    may I add my graphics card ( an ATI Radeon 6870 ...) doesn't like MPLABX at all and frequently crashes ...
    but everything is fine With MPLAB 8.84 ...
    Sep 2007
    I just kicked back a beta version for a minor fix. I hope to release an updated plugin tomorrow.
    Charles Leo
    http://melabs.com
    Mar 2012
    Up
    same problem:
    "The program file could not be loaded: java.lang.NullPointerException"
    Sep 2007
    I've updated the plugin download.
    http://pbp3.com/downloads/com-melabs-pbptoolchain.zip
    Let me know what you find.
    I tested with a PICkit3. Source-level debugging works and it will show PBP variables in the watch window.
    MPLABX still seems a bit spotty for debugging. I'm hoping for some improvement in version 1.20.
    Charles Leo
    http://melabs.com
    Italy
    Hi Charles,
    I still have to understand how MPLABX works, but I can confirm that with the udated plugin I no longer have that java error after build.
    I'll come back here again next week. For the moment, many thanks.
    Marco
    Mar 2012
    Quote Originally Posted by Charles_Leo View Post
    Thank you, Charles
    No errors with new plugin.
    Fabio
    Nov 2009
    Virginia, USA
    Works like a charm for me also. Thanks !
    Gary-W4GNS
    MicroCode Studio Plus 5.0.0.2 MCSPX
    PBP 3.0 Gold Edition 3.0.5.4
    Tickled Speechless using PBP 3.0
    Hi, SupaCharles
    Works fine here :
    CLEAN SUCCESSFUL (total time: 62ms)
    make -f nbproject/Makefile-default.mk dist/default/production/Servotest.X.production.hex
    cp Servotes.HEX dist/default/production/Servotest.X.production.hex
    rm -f Servotes.COF
    Loading C:/Program Files/Microchip/MPLAB IDE/Projets/X/Servotest.X/dist/default/production/Servotest.X.production.hex...
    Loading completed
    lots of thanks to you once more ...
    Hi, Charles
    just a little error I Can't explain ...
    make[1]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
    make -f nbproject/Makefile-default.mk dist/default/production/Train_Rentrant.X.production.hex
    make[2]: Entering directory `C:/Program Files/Microchip/MPLAB IDE/Projets/X/Train_Rentrant.X'
    "C:\PBP3\PBPX.EXE" -ampasmx -k# -os -p16f628 Train_R.pbp
    Error[113] C:\PBP3\PBPPIC14.LIB 451 : Symbol not previously defined (TMR1)
    Error[113] C:\PBP3\PBPPIC14.LIB 465 : Symbol not previously defined (TMR1)
    Error[113] C:\PBP3\PBPPIC14.LIB 479 : Symbol not previously defined (TMR1)
    Compiles ( and runs in real life ... ) fine with MPLAB 8.84, but doesn't want to compile with MPLABX ...
    looks a definition for TMR1 ( as a word ) is missing somewhere ... but where ???
    Here is the program
    '*  Name      : Train_Rentrant
    '*  Author    : Alain
    '*  Notice    : Copyright (c) 2010
    '*            : All Rights Reserved
    '*  Date      : 9 avr. 2012
    '*  Version   : 1.0
    '*  Processor :
    '*  Notes     : Gestion de train rentrant électrique
    'Configuration
        __CONFIG  _BODEN_ON &_CP_OFF & _PWRTE_ON & _WDT_ON & _LVP_OFF & _MCLRE_ON  & _XT_OSC
    'Config Timer 1
    T1CON  = 110100     ' 1/8, internal osc,stopped
    INTCON = 000000
    PIE1 = 000001
    PIR1 = 0
    TMR1 = 0
    'Definitions
    DEFINE PULSIN_MAX 2500
    DEFINE BUTTON_PAUSE 255
    'Definitions
     Temp  var Word
     Servoval var Word
     mesure      var Byte
     meanval     var Byte
     dureeprog   var Byte
     Pos1  var Byte
     Pos2  var Byte
     Timecounter var Byte
     echantil    var Byte
     delay  var Byte
     side        var byte
     Timeout  var Byte
     CLEAR
    ' I/Os
     Sorti       var PORTA.0 ' Closed = GND
     Rentre  var PORTA.1 ' Closed = GND
     LedA  var PORTA.2
     LedB        var PORTA.3
     prog       var PORTB.0 ' jp2 reglage enclenchement
     Signal  var PORTB.1 ' Entrée Signal
     Boost  var PORTB.3 ' Sortie PWM
     T2   var PORTB.4
     T3   var PORTB.5
     T8   var PORTB.6
     T5   var PORTB.7
    'Initialisation des ports
     CMCON  = 7    ' All digital
     PORTA   = 0
     PORTB   = 000000
     TRISA  = 000011
     TRISB  = 000011
     Neutre   CON 150
     Traveltime  CON 50
     DATA @1,180,170,130,1   ' Protection 1ère utilisation
    'Lecture des valeurs en EEPROM
     READ 1, Dureeprog, Pos1, Pos2, Side
     IF dureeprog <> 255 THEN start
    'Mesure de l'impulsion d'enclenchement
    mesurepro:
     dureeprog = 255
     LOW LedA
     LOW LedB
    mesurep:
     LedA  = 0   ' Led Verte
     LedB  = 1
     FOR echantil = 1 to 50
     PULSIN Signal,1,mesure
     IF ( mesure < 75) OR ( mesure > 220 ) THEN
      GOTO mesurep
     IF dureeprog = 255 THEN valable
    ' Stability check
     IF ( mesure < ( dureeprog - 1 )) OR ( mesure > ( dureeprog + 1 )) THEN
      GOTO mesurep
    ' Valid mesure
    valable:
     dureeprog = mesure
     NEXT echantil
     LedB  = 0
     delay  = 0
     BUTTON prog,0,255,0,delay,1,mesurepro 'Enlever le cavalier
    ' Calcul Pos1, Pos2
     SELECT CASE Dureeprog
      CASE is => ( Neutre + 20 )
       Pos1  = ( Dureeprog - 10 )
       Temp  = 2*Neutre - Pos1
       Pos2  = Temp
       Side = 1
      CASE is < ( neutre - 20 )
       Pos1  = ( Dureeprog + 10 )
       Pos2  = Temp
       Side = 0
      CASE ELSE
        IF Dureeprog => Neutre THEN
         Pos1 = Neutre + 10
         Pos2 = Neutre - 10
         Side = 1
         Pos1 = Neutre - 10
         Pos2 = Neutre + 10
         Side = 0
     END SELECT
     WRITE 2,Pos1, Pos2, Side    ' Save Switching Positions
    start:
     IF Timeout THEN      ' Locking for Timeout
      GOTO NoSignal
     Servoval = 0
     FOR Echantil = 1 to 5     ' Check 5 cycles and take mean value
        GOTO  NoSignal
      IF Meanval = 0 THEN Valable1
     ' Stability check
      IF ( mesure < ( meanval - 2 )) OR ( mesure > ( meanval + 2 )) THEN
       GOTO start    ' Reset cycle
     Valable1:
      Servoval = Servoval + mesure
      NEXT echantil
     Meanval = Servoval/5
     IF Side THEN
      SELECT CASE Meanval
       CASE is => pos1
        'IF T2CON.2 = 0 THEN HPWM 1,127,20000
        GOTO UP       ' _________________  Gear UP
       CASE is <  pos2
        GOTO DOWN      '__________________  Gear DOWN
       CASE Else
        'IF T2CON.2 = 1   THEN HPWM 1,0,20000
        GOTO NoMove      ' _________________  Gear LOCKED
      END SELECT
      SELECT CASE Meanval
       CASE is <= pos1
       CASE is >  pos2
       CASE Else
      END SELECT
    UP:
     IF Rentre = 0 OR Timeout THEN ' Verification fins de course
      T1CON.0 = 0    ' Stop the timer
      TMR1.0 = 0    ' Reset the timer
      LedA = 1    ' Solid GREEN Led
      LedB = 0
      GOTO NOMOVE
     T1CON.0  = 1
     LOW  T8     ' T8 + T3 OFF
     LOW  T3
     PAUSEUS 100
     HIGH  T5     ' T5 + T2 ON
     HIGH  T2
     LedA  = 0
     IF PIR1.0 THEN
       LedB = ~ LedB
      TMR1 = 0
      TimeCounter = Timecounter + 1
      IF Rentre THEN
       IF timecounter => TravelTime THEN
           Timeout = 1
        GOSUB NoMove
       GOSUB NoMove
     TMR1.0  = 1
     PIR1.0  = 0      ' Clear Flag
     GOTO Start
    DOWN:
     IF Sorti = 0 OR Timeout THEN   ' Verification fins de course
      LedA = 0    ' Solid RED Led
      LedB = 1
      GOTO NOMOVE
     T1CON.0 = 1
     LOW  T5     ' T5 + T2 OFF
     LOW  T2
     PAUSEUS 100
     HIGH  T8     ' T8 + T3 ON
     HIGH  T3
     IF PIR1.0 THEN
      LedA  = ~ LedA
      TMR1  = 0
       IF Sorti THEN
         Timeout = 1
         GOTO NoMove
        GOTO NoMove
     LedB   = 0
     T1CON.0  = 1
     GOTO Start
    NOMOVE: ' Bridge switched OFF , Led Remains unchanged
     'Brake a While
     LOW  T5     ' Hi part of Bridge OFF
     LOW  T8
     Pauseus 100
     HIGH T2     ' Low part of Bridge ON
     HIGH  T3
     PAUSE 500
    ' LOW  T5     ' Hi Bridge OFF
    ' LOW  T8
     LOW  T2     ' Low Bridge OFF
     LOW  T3
     GOTO Start
    NoSignal:
     IF PIR1.0 THEN
      LedA = ~ LedA
      TMR1 = 40536    ' Quick 5Hz RED Flash
     LedB  = 0
     T1CON.0  = 1
     GOTO Start
    The 16F628.inc file for MPASMX doesn't have an EQU for TMR1.
    The 16F628.inc file for MPASM in MPLAB 8 does have TMR1.
    You can add this to your program for a workaround ...
        ifndef TMR1
    TMR1 = TMR1L
    Hi, Darrel
    Thanks for the tip.
    I finally have modified the Mpasmx .inc file ...
    With PBP3 there is no more need to modify the PBP . inc files .... but the Mpasmx have to be now ....
    You right : customers ALWAYS complain !!!
    Tcrook's Avatar
    Tcrook Guest
    Just wondering if there are any updates on this. Been using PBP 2.50 and MPLAB v8.15 for many years.
    After 30 hours of trying, I have yet to get to first base trying to get MPLABX v3.45 and PBP (2.50 or 3.08) to play together. Can open the PBP source file and edit but MPLABX says the project file is empty when building. Navigator view shows the file as being there.
    Using Windows 10 if it matters.
    Going back to an old desktop PC with MPLAB 8.15 and PBP 2.50 to get some work done.
    Win10, tried executing as administrator?
    Tcrook's Avatar
    Tcrook Guest
    Yep, tried being Administrator, still no joy. I did go back to IDE v8.92 and things started working. Think I've officially given up on MPLABX. Nothing should be that hard. Or maybe I'm getting too old to learn new shit.
    You're not alone, that's all I've got to say unfortunately.
    MCSP is simple to use but lacks advanced features (source level debugging mainly), isn't aware of some features in added in PBP3 and is prone to crashing on several systems (mine including) which SUCKS.
    MPLAB 8 is outdated and lacks support for the latest devices and MPLABX is too bloody hard to set up and apparently Microchip keeps changing things and Melabs can't keep up. It's quite a mess IMHO.
    I agree with Henrik.. I just use what was given.. MCSP: crashes on my systems as well, especially when copying and pasting stuff..
