overclocking internal oscillator?
Results 1 to 14 of 14
    Dec 2010
    Default overclocking internal oscillator?
    I have a 16f688 outputting music using the FREQOUT command. When I define the internal oscillator at 8 MHz the audio is slightly warbled and plays faster than I would like, but when I define the internal oscillator at 10 MHz, which is higher than the chips internal oscillator is rated for, the music plays exactly how I want it to.
    My question is will this damage my chip? It seems to work alright and I'd like to keep the music this way. Or should I buy a 10 MHz crystal just to be safe?
    Here is the datasheet: http://ww1.microchip.com/downloads/e...doc/41203d.pdf
    Thanks guys,
    Emerson
    Default Re: overclocking internal oscillator?
    If all you are doing is Defining the oscillator frequency with the DEFINE OSC statement then NO, you are not doing any harm to the processor. The DEFINE statement is mearly telling PBP of the intended frequency so statements like PAUSE and the like run in the required amount of time.
    EN82fn
    Aug 2003
    Interesting.. DEFINEing a higher clock speed for a given actual clock speed that is constant should make everything slower, not faster.
    Dec 2010
    What you said is right. I have the music playing while a title screen loads on my tv, and when I DEFINE the oscillator speed at 10 MHz, the music stops when the screen is finished loading. If I DEFINE the oscillator speed at 8 MHz though, the music finishes about a second faster than the screen loads. I prefer the slower speed, I just don't understand why it happens.
    Aug 2003
    Ah, that is the correct way around.
    If you define a slower speed, but don't change your actual clock, as stated above,
    PBP will make adjustments to timing to compensate for the different clock freq.
    So if you DEFINE OSC 8, but run at 4 MHz, a PAUSE 1000 statement should take 0.5 seconds to execute.
    Art, it will take 2 sec.
    PBP thinks it is 8MHz, bit clock is half. So delays are double.
    Aug 2003
    Whoops!
    Dec 2010
    Well it doesn't seem like it will hurt the chip any. Thanks again for the help guys.
    Sure not! If you increase the clock frequency, you will reach a point that it will just not work, or at least reliable.
    I just love this thread... Nice idea,,, overclock an oscillator you have NO control over other than the divider..... Hat a Hoot....
    EN82fn
    Aug 2003
    Ya reckon? Raise voltage to the entire chip and it will be overclocked.
    Sure will fail to be reliable at some stage though!
    Quote Originally Posted by emerson View Post
    Emerson
    Written like that, It looks like some kind of mismatch ...
    Using " FREQUOUT " when defining the correct osc frequency gives the correct frequency, or close to it ... nothing else !
    so, as it seems to be PBP ... may we see your source program and especially the config section ???
    You can overclock, at your own risk.
    http://www.picbasic.co.uk/forum/showthread.php?t=15993
    Yes, but how to Re: overclocking internal oscillator?
    Maybe overclocking about 1% with the osctune register?
    http://www.scalerobotics.com
