rotate bytes in array
Results 1 to 19 of 19
    Default Re: rotate bytes in array
    Quote Originally Posted by LinkMTech View Post
    ...It meant more typing but saved some space and time.
    I'm not surprised at all. We quickly forget that FOR-NEXT commands are a combination of ADDs, IFs and GOTOs in the background. The only problem is that the compiler has to make it generic to work for many circumstances; like the STEP -1 example. So now it has to include SUBTRACTs as well, that generates even more code whether you need it or not.
    I'm simplifying, but that's pretty much it.
    I use the simplified commands 'cause I haven't run out of space yet, and speed hasn't been an issue yet either. But if I ever reach that point, that's when I start breaking them down to their basic elements.
    EDIT: Assembler class was back in '78-'83 era, yeesh...
    Nov 2007
    West Covina, CA
    Thanks for the insight Robert.
    The PBP simplified commands are the very reason I started "programming" especially after seeing the difference Bruce gives on his site.
    My PIC16F1823 is nearing the end with 2020 words used and just happened to need the space and faster time. Plus it was just rewarding to figure this out on my own and thought I'd share a little for some other newbie out there.
    Louie
    Aug 2003
    So far our score in PBP knowledge:
    Robert 1 .... Art 56,743
    I wouldn't say that, and you might not if you saw what my code looks like when only written for myself!
    I'll end up using it because that part of the program can be slow, so I'd rather it tight.
    Just had to remember to fill up the array with an acceptable value at initialisation so the low voltage cutout
    doesn't kick in straight away (values start out all zeros), so I initially fill the array with the first stable voltage reading.
    Hi, Art
    a good question to ask : do you need to store the 30 values for another purpose than calculate your mean value ???
    because @ each measurement you could calculate:
    new_meanval = (old_meanval*29 + last_measure) /30 ... which gives you the mean value over the 30 lasts measurements ! ( called "rolling average", if I'm right )
    note here 32 measures would be best for dividing time ! so :
    new_meanval = (old_meanval*31 + last_measure) >> 5 ...
    I think Darrel posted a while ago a nice routine about that ...
    I remember he also posted about a 48 level stack ... may be ideas to take there ...
    Aug 2003
    Yes, the device is also a car alarm that is triggered by internal lights that come on when the vehicle door is opened.
    The line is 12 Volts live until a door is opened & a resistor divider provides 5 Volts for the pic's input.
    If ever I get a false alarm, I want to save the last thirty seconds voltage readings to see if I can prevent it.
    When the car battery goes cactus my alarm might also sound since the resistor divider is at the unregulated side,
    and may not produce the voltage for logic high at the pic pin.
    I could have the program look at the last thirty seconds values to prevent these false triggers.
    from your decription, the alarm part could be done with 1's and 0's, door opened/closed, no a/d overhead, just digital pin, "0" at < 2.5volts and "1" > about 2.5volts. No help checking batt voltage though...??
    Don
    Just a technicality; I'd feed directly from the door switch, not the lamp itself. You could have forgotten the interior lamp switch in the OFF position, the lamp could be burnt, or the robbers might know this trigger; they could just break the window, turn off the lamps and open the door.
    I know it's highly unlikely, but it would make your device even better.
    Aug 2003
    It does get it's input from the door switch
    It's live until any door is opened, then it is earthed.
    That is why I might get a false trigger as the batteries die.
