rotate bytes in array
Results 1 to 19 of 19
    Feb 2011
    Michigan, USA
    Default Re: rotate bytes in array
    instead of a for/next shift, how about a in-place overwrite. (instead of shifting the data, shift the index variable.)
    index = 0
    Loop:
    adResult = {...new voltage value}
    arraySum = arraySum - arr[index]
    arr[index] = adResult
    arraySum = arraySum + adResult
    if index = 29 then
    index = 0
    index = index + 1
    goto Loop
    Mike -
    Aug 2003
    Mike, is the compile size smaller?
    I can't really check in my project because it appears code is being fragmented over several pages
    after I crossed the first boundary.
    Robert, Didn't know you could use a STEP -1 directive,
    but if it works, it's shorter, and saves a useless byte.
    It appears to be working nicely, but I will shorten it if possible.
    It's for my car computer I've posted about here before.
    With the vehicle running, the voltage reading is live.
    With the engine stopped, but accessories relay on,
    the stereo amplifiers tend to cause the voltage to jump around (understandably).
    The thirty second average is then displayed and acted on to turn accessories off if the average is too low.
    Feb 2011
    Michigan, USA
    Art,
    don't know if it's smaller. i was going for speed rather than code size.
    Mike -
    USA - Arizona
    Adding a new voltage reading every second to calculate a new mean voltage over thirty seconds
    But, perhaps you want to look at rolling averages...
    http://www.pbpgroup.com/modules/wfse...hp?articleid=7
    http://www.picbasic.co.uk/forum/showthread.php?t=12183
    http://www.picbasic.co.uk/forum/showthread.php?t=8046
    http://www.picbasic.co.uk/forum/showthread.php?p=41702
    http://www.picbasic.co.uk/forum/cont...ith-hysteresis
    Nov 2007
    West Covina, CA
    Guys,
    May not be the solution for Art's project, but this post interested me because I was also stumped trying to shift bytes of data FIFO and ended up making something work for me.
    I liked the FOR/NEXT approach given here and thought I would try it since it looked faster and smaller since I'm really collecting 32 bytes instead of 12 in this example.
    My kludge: This scheme uses 24 words and takes 12.5us
    DEFINE OSC 8
    RX      VAR BYTE        ' Buffer data
    XYZ_val VAR BYTE[12]    ' Accelerometer XYZ data
    TC_OUT  VAR PORTC.4     ' Test point to measure loop time
    Load_array:
    TC_OUT = 1
        XYZ_val[0] = XYZ_val[1]     ' Oldest data
        XYZ_val[1] = XYZ_val[2]
        XYZ_val[2] = XYZ_val[3]
        XYZ_val[3] = XYZ_val[4]
        XYZ_val[4] = XYZ_val[5]
        XYZ_val[5] = XYZ_val[6]
        XYZ_val[6] = XYZ_val[7]
        XYZ_val[7] = XYZ_val[8]
        XYZ_val[8] = XYZ_val[9]
        XYZ_val[9] = XYZ_val[10]
        XYZ_val[10] = XYZ_val[11]
        XYZ_val[11] = RX            ' Newest data
    TC_OUT = 0
    Was surprised to to find that this scheme uses 43 words and takes 216us:
    DEFINE OSC 8
    Load_array:
    TC_OUT = 1
        FOR z = 0 to 10
            XYZ_val[Z] = XYZ_val[Z+1]
        NEXT z
        XYZ_val[11] = RX
    TC_OUT = 0
    It meant more typing but saved some space and time.
    Louie
    Quote Originally Posted by LinkMTech View Post
    ...It meant more typing but saved some space and time.
    I'm not surprised at all. We quickly forget that FOR-NEXT commands are a combination of ADDs, IFs and GOTOs in the background. The only problem is that the compiler has to make it generic to work for many circumstances; like the STEP -1 example. So now it has to include SUBTRACTs as well, that generates even more code whether you need it or not.
    I'm simplifying, but that's pretty much it.
    I use the simplified commands 'cause I haven't run out of space yet, and speed hasn't been an issue yet either. But if I ever reach that point, that's when I start breaking them down to their basic elements.
    EDIT: Assembler class was back in '78-'83 era, yeesh...
    Nov 2007
    West Covina, CA
    Thanks for the insight Robert.
    The PBP simplified commands are the very reason I started "programming" especially after seeing the difference Bruce gives on his site.
    My PIC16F1823 is nearing the end with 2020 words used and just happened to need the space and faster time. Plus it was just rewarding to figure this out on my own and thought I'd share a little for some other newbie out there.
    Louie
    ...Robert, Didn't know you could use a STEP -1 directive,
    but if it works, it's shorter, and saves a useless byte...
    Yup, got off my lazy butt and got the manual, it's in there.
    So far our score in PBP knowledge:
    Robert 1 .... Art 56,743
