16f628 LCD
Results 1 to 3 of 3
Thread: 16f628 LCD
    Aug 2009
    Paso Robles California
    Default 16f628 LCD
    Im making a new Proto board for a 16f628 and 16f877, are there any problems using 16f628's portA for 4 bit LCD output ? other than turning on Digital.
    Default Re: 16f628 LCD
    On the 628 RA4 is open drain so it can't actively drive the output high, only pull it low. A pullup resistor is needed to be able to get a logic '1' on that pin. RA5 doesn't have any output drivers at all so it's input only.
    Aug 2009
    HenrikOlsson
    Thanks for your reply RA5 I did not bring out from the 16f628 to the header so ok there and RA4 is used as RS and pulled high with resistor and using A0 ~ A3 and my 4 data bits looks like Im ok
    thank you for the reply
    Larry
