(2) 10 Bit Inputs, Convert one to 8 bit and display both on LCD
Results 1 to 2 of 2
    Feb 2005
    Indiana
    Default (2) 10 Bit Inputs, Convert one to 8 bit and display both on LCD
    I have my x/y joystick control working with 8 Bit inputs for tank style control(i don't want to go through that algorithm again), but I want to use a temp sensor(LM35DT) with 10 Bit input for better resolution. I have tried the bit shift method before displaying the 8 Bit result without success. I would like to know for sure what the 8 bit value is by displaying on the LCD. Maybe that can't be done since the 8 bit must be left justified while the 10 bit value must be right justified. 16F877A Code below:
    ' PicBasic Pro program to display result of
    ' 10-bit and 8-bit A/D conversion on LCD
    ' Connect analog input to channel-0,8-bit and channel-1,10-bit (RA0)
    @ DEVICE HS_OSC
    DEFINE OSC 20
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTD
    Define LCD_RSBIT 2
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    define LCD_RWREG PORTD
    define LCD_RWBIT 3
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    'ADCON1 =000000 'Set PORTA analog and Right(1),Left(0) justify result
    adval0 var word ' Create adval to store result
    adval1 var word
    duty var word
    'Set up (2) Channel Analog input
    TRISD=0
    TRISE=0
    TRISA = 000011 ' Set PORTA.0 & PortA.1 to input,ALL THE REST OUTPUTS
    ' ADCON1 =000000 'Set PORTA analog and right justify result
    PORTE.2=0 ' Turn off leds so you can use the lcd display
    PORTD.3=0 ' LCD R/W line low (W)
    Pause 500 ' Wait .5 second
    LCDOUT 254,1
    PAUSE 500
    'Set up PWM
    PR2=9
    TRISC.2=0 'Set CCP1 to Output
    CCP1CON=001100 'SET CCP1 TO PWM
    T2CON=000100 'SET TIMER2 TO "ON";PRESCALE=1
    duty=5
    loop:
    adcon1=000000
    ADCIN 0, adval0 ' Read channel 0 to adval
    ' adval0=adval0>>2
    pause 50
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "8 Bit=: ", dec adval0 ' Display the decimal value
    ' Pause 100 ' Wait .1 second
    adcon1=000000
    adcin 1,adval1
    lcdout $fe,$c0
    lcdout "10 Bit=: ",dec adval1
    ' pause 1000
    Goto loop ' Do it forever
    JRudd
    Apr 2008
    Default Re: (2) 10 Bit Inputs, Convert one to 8 bit and display both on LCD
    Not sure watt you want to do.
    As far i can see both your variables adval0 and adval1 are storing a 10 bit number in decimal range 0 to 1023
    if you divide any of them by four they turn to 8bit ranging from 0 to 255 decimal number.
    Fernando
