what is wrong in this code
Results 1 to 14 of 14
    Jan 2012
    Default what is wrong in this code
    i want to light the led at portb.0 when the output of comparator is high and to light led at portb.1 when comparator output is low, my code compiled successful and on running this code light a ked at portb.1 always without depending on the output of the copmarator, the output of the comparator doesn't depend on the inputs...what is wrong hear
    this is my code and i attach my circuit
    C10UT VAR CMCON.6
    ADCON1=7
    CMCON=2
    PORTB=%00000000
    TRISB=%00000000
    lop:
        if c10ut=1 then
        portb.0=1
          portb.1=1
          goto lop
    Jan 2006
    Istanbul
    Default Re: what is wrong in this code
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _BODEN_OFF & _LVP_OFF & _CP_ON
    CLEAR
    TRISA  = 255
    TRISB  = 0
    ' Comparator Control
    CMCON=100101
    CompOut var CMCON.7
    ' CM7 C2OUT Comparator Output 2 (Read Only)
    ' CM6 C1OUT Comparator Output 1 (Read Only)
    ' Voltage Reference Control
    VRCON = 0
    Pauseus 10 ' VREF to settle.
    PORTB = 0
    LED_A var PORTB.0
    LED_B var PORTB.6
    Start:
        led_a = compout
        led_B = ~compout
        pause 1
        goto start
    Jan 2012
    this is my code
    C10UT VAR CMCON.6
    ADCON1=7
    CMCON=2
    PORTB=000000
    TRISB=000000
    lop:
     if c10ut=1 then
     portb.0=1
    portb.1=1
      goto lop
    When C1Out is 1 you set PortB.0 HIGH and when C1Out is 0 you set PortB.1 HIGH. But there is no code in the loop to set either of the outputs LOW again.
    lop:
      if C1Out = 1 THEN
        PortB.0 = 1   ' One on
        PortB.1 = 0   ' The other off
        PortB.0 = 0   ' On off
        PortB.1 = 1   ' The other on
    GOTO lop
    Jan 2012
    lop:
      if C1Out = 1 THEN
    GOTO lop
    yah HenrikOlsson help me on that edit where necessary so that it can work as i want, iam a begginer in the pics progrmming, thanx indvance
    Jan 2012
    Quote Originally Posted by chitalula View Post
    sayzer i tried to run your but it didn't do anything, i don't know why. and i need a comparison in my code can you add too?
    I already DID just that. The code in my previous message IS edited so it should work the way I think you want.
    Jan 2012
    thanx for your suggestion. on stimulation if the input voltage equal to vref else statement always and if the input voltage is higher than or less than Vref else statement is executed too. it seems the "if statement" is not functioning, have you any solution on that case, i have no way to go forward , help me please
    I'm pretty sure that the IF statement executes as it should. The problem is likely that the C1Out doesn't actually toggle.
    According to your schematic in the first post you have one input to RA0 and the other to RA2. As far as I can see in the datasheet, section 12.1, the inputs to comparator 1 is RA0 and RA3.
