Cruise Control
Results 1 to 21 of 21
Thread: Cruise Control
    Aug 2003
    Default Re: Cruise Control
    What you want is not much different from the interrupt code I posted in your other thread.
    You just need to add a line to count the interrupt events.
    Regardless, I would begin with DTs Elapsed Time code,
    and add the portb.0 interrupt from there.
    If you just get the elapsed timer working,
    so you can check within any program that the SecondsChanged
    variable is set (a second has ticked over),
    it already contains an interrupt routine for a timer.
    Then trust me, I'm in a good position to help you.
    You don't add to what you've got,
    best put it aside and use parts of it that do what you want,
    but consider beginning with the Elapsed timer demo and adding what you need to that.
    Aug 2008
    Well S.C. , I've done my own work, but there are several concepts that are a little beyond my grasp, although I'm trying. I am 67 years old and its a little bit hard to understand when someone says, " Just cut and paste this here, and write an assembler routine and add it here....". I have bought books like, "Revolutionary Assembly Language" and "Learning Assembly Language the Easy Way", all to no avail. I guess its like a cave man trying to understand a computer. At some point in our lives things just don't sink in that well. But I do appreciate Art's input but its like asking your mechanic what is wrong with your car and he replies "read the book".
    Maybe I should just quit, throw away the development board and PBP and just watch tv all the time, would that be better?
    Another option (still involving interrupts though) is to feed the pulses to the input of TMR1 and set that up as a counter. That way the the pulses are counted in hardware and you can just "collect" the count at a suitable interval - which is where the interrupt comes in (or you could use PAUSE if you don't need to do anything else at the same time).
    TMR1H = 0  'Clear count
    TMR1L = 0
    T1CON.1 = 1  'Set TMR1 as counter, clock on T1CKI
    Now the TMR1 will count the pulses on the T1CKI-pin and you can read it like
    PulseCount VAR WORD
    PulseCount.HighWord = TMR1H
    PulseCount.LowWord = TMR1L
    If you don't want to reset the TRM1 count each time you can just take the difference between 'this' reading and the 'last' reading
    oldCount VAR WORD
    oldCount = PulseCount
    PulseCount = PulseCount - oldCount
    If you call this code at a specified interval (by timer interrupt or a simple PAUSE) you'll always have the current 'speed' in the variable PulseCount. This could be done with ON INTERRUPT but DT-INTS would be 'better'. We tend to say it's easy, which it is once you know how to do it but it can be intimidating at first. However there are many examples for DT-INTS and timer interrupts on the forum. If you can't find it and/or you need help that's what we're here for but give it a try first - if this is a suitable approach to your project of course.
    Aug 2008
    Thanks Henrik,
    Now I can understand this code. Using the TMR1 is exactly what I need to do. I notice that you use both a Highword and a low word, I assume this detects the rising and falling edges of the signal. But I'm still a little confused, do I add the high and low counts together? AAAAgggg.... I'm thinking of getting Flowcode 5 and throwing PBP away. Any thoughts?
    No, TMR1 is 16bits wide so it consists of two bytes, TMR1H and TMR1L, meaning it can count from 0 to 65535 pulses before it rolls over. These two bytes gets "put together" into the WORD size variable called PulseCount.
    EDIT: Get Flowcode, perhaps.... Throw away PBP, not a chanse! Learning curve, yes of course but you'll get the hang of it. I bet Flowcode comes with a learning curve as well.
    Aug 2008
    O.K. but where is the interrupt in your program? I've had PBP for 5 or 6 years now and there are somethings I just don't get and I guess never will, plus people are "tight" with their code, I guess they think you might make money off of it, heaven forbid. But with Flowcode 5 they give 50 free hours of online courses, they have a forum where you can chat with the actual designers of the software and there are numerous examples covering just about every subject in-depth.
    There is no interrupt in my program, since using DT-Ints have been covered many many times before on this forum and is pretty well documented on Darrels web-site I thought you might have a go at it yourself. I don't think it's matter of being tight with code it's just that each and every application is a little different so it's not just a matter of here you go, use this it'll work exactly the way YOU want.
    I have no way of testing this here so this may actually be more of a problem than help but since you seem reluctant to try yourself here goes nothing.
    First you need to download the files from Darrels web-site and place them in the PBP directory (or in the project directory). Then
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    Then you need to configure the interrupt source and tell the system which subroutine to call when the interrupt occurs
            INT_Handler   TMR0_INT,  _UpdateCount,   PBP,  yes
    Here we tell the system that we want to trip an interrupt when TMR0 overflows. When that happens we want the UpdateCount subroutine to be called. That subroutine is to be written in PBP and we want the system to automatically clear the interrupt flag for us.
    Now you need to actually set up TMR0 so it interrupts at a suitable interval. At 20MHz it ticks a long a 5Mhz meaning , since it's 8bits wide, it'll overflow every (1/5000000)*256 = 51.2us. That'll be a little fast for you I think but luckily TMR0 has prescaler which you can use if disable the Watchdog timer. With the prescaler set to 1:256 you'll get an interrupt rate of (1/5000000)*256*256=13.11072ms or ~76Hz.
    TMR0 is controlled thru OPTION_REG so
    OPTION_REG.5 = 0
    OPTION_REG.4 = 0
    OPTION_REG.3 = 0
    OPTION_REG.2 = 1
    OPTION_REG.1 = 1
    OPTION_REG.0 = 1
    This should set TMR0 up in "free running mode" with a prescaler of 1:256 meaning it'll overflow every 6.5536ms.
    Then you set up TMR1 as a counter as shown before.
    Then you enable the interrupt
    @ INT_ENABLE TMR0_INT
    Now, every time the TMR0 overflow it'll call the Interrupt Service Routine called UpdateCount
    UpdateCount:
    Tick VAR BYTE
    PulseCount VAR WORD
    oldCount VAR WORD
    Tick = Tick + 1
    If Tick = 76 THEN  ' Count 76 interrupts to get roughly one second
      oldCount = PulseCount   ' Previous count
      PulseCount.HighByte = TMR1H
      PulseCount.LowByte = TMR1L
      PulseCount = PulseCount - OldCount  'Take difference between this and the previous difference.
      Tick = 0
    @ INT_RETURN   ;Return from ISR
    Now, PulseCount will be updated with the current speed automatically, in the background, once per second.
    Don't expect this to just work. I have no way of testing it here so use it as a starting point.
    Read the datasheet and compare the settings, does it match, does it add up? Read Darrels website. Do you understand how it works.
    I wouldn't expect to buy Flowcode and NOT having to read any documentaion. There ARE numerous example (here on the forum), there ARE a lot of people here to help, Darrel (who now works for MELABS) is here and if that's not enough you can always visit the forum at MELABS website where the other guys from MELABS answers questions too. I wouldn't expect anyone to write the application for you though.
