Bad 16f88
Results 1 to 14 of 14
Thread: Bad 16f88
    Aug 2008
    Portugal
    Default Re: Bad 16f88
    Quote Originally Posted by Picstar View Post
    No, these were new chips that I entered some simple code into and they froze. This is what I entered,
    ' Timer countdown test
    trisa = 0
    porta = 0
    Start:
    I var byte
    for I = 1 to 2000
    porta.0 = 1
    pause 5000
    goto Start
    Why you say its locked?
    That code posted don't do nothing, did the code compile without errors? Because its missing the "next" of the "for" command!
    Thanks and Regards;
    Gadelhas
    not only that but, where are you turning off the port bit?
    EN82fn
    Aug 2008
    You are both right, made a error when I posted. HERE is what I entered:
    the purpose of the whole program is to give me a visual indication of how long it takes to the chip to execute a loop and count down. I need this info for setting timing on portions of my programs. Hope this makes sense. P.S. my setup may not be correct but I'm an old geezer.
    trisa = 0
    porta = 0
    Start:
    I var byte
    for I = 1 to 2000
    next I
    porta.0 = 1
    pause 5000
    Aug 2008
    Update, I just realized that (I) should be a VAR WORD, since it will be over 255. Thanks for your input guys but the problem remains that I still cannot program these chips that talked about.
    trisa = 0
    porta = 0
    Start:
    I var word
    for I = 1 to 2000
    next I
    porta.0 = 1
    pause 5000
    Dec 2010
    Your posted code has several problems, beginning with the lack of capitalization for the register names.
    Do you intend it to turn PORTA.0 to a one and nothing else? If so, why delay?
    Your issue is likely with the configuration bits. Please post your code for configuration...
    Nov 2008
    I have run to this many times. I used my Pickit2(tm) to erase the pic and then is was ok.
    CharlieM
    Using PBP3
    MCSPX
    I posted the solution in your other thread have you tried it?
    Aug 2008
    Charlie, please refer to post #6 above, I use this to set the timing of some of my programs. I know my Cap. is off, just posting an experiment, Thanks for responding.
