Building an I2C monitor ... but i think it is not Slave....
Results 1 to 9 of 9
    Feb 2010
    Default Re: Building an I2C monitor ... but i think it is not Slave....
    I am happy to say that the bit-banging I2C monitor is done.
    It is written all in PBP , and uses interrupts for the input-bit sensing using a...12F1822 at... 32MHz of course.
    Tommorow i will post the code here , since i dont' have it now here.
    Cheers!
    Feb 2010
     __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_OFF & _BORV_19 & _LVP_OFF
      DEFINE OSC 32
        TX  VAR PORTA.0
        SCL VAR PORTA.1
        SDA VAR PORTA.2
        SCLB VAR PORTAB.1
        SDAB VAR PORTAB.2
        SCLF VAR IOCAF.1
        SDAF VAR IOCAF.2
        BIT_COUNTER VAR BYTE
        STOP_COUNTER VAR BYTE
        BYTE_READY VAR BIT
        BYTEINT VAR BYTE
        BYTEINT2 VAR BYTE
        BYTEINB VAR BYTE
        BYTEIN VAR BYTE[30]
        PORTAB VAR BYTE
        BYTE_COUNTER VAR BYTE
        BYTES_RECEIVED VAR BYTE
        STOPFLAG VAR BIT
        OSCCON = %01110000
        IOCAN = %00000100
        IOCAP = %00000110
        ON INTERRUPT GoTo INT   ' Declare interrupt handler routine
     START:
        PAUSE_1000
        OPTION_REG.7 = 1         ' DISABLE PORTB PULLUPS
        PORTA = %00000110        ' SWAP PORTA.0 /PORTA.2 FOR SMALL PCB
        TRISA = %00001110        ' SWAP PORTA.0 /PORTA.2 FOR SMALL PCB
        ANSELA = $00             ' MAKE ALL INPUTS DIGITAL I/O PINS
        WPUA = $00
        BIT_COUNTER = 0
        BYTE_COUNTER = 0
        INTCON = %10001000        ' Enable GLOBAL AND IOCHANGE interrupts
    MAIN_LOOP:
        IF STOPFLAG = 1 THEN
        '/ Here we have the received bytes in the array BYTEIN(x)
        ' The size of the array is in the variable BYTES_RECEIVED.
        ' You have to process them  and then ...
        BYTE_COUNTER = 0 ' in order to get the next bytes
        GOTO MAIN_LOOP
    '================ BIT BANGING interrupt handler  ============================
    Disable                                ' Don't check for interrupts in this section
    INT:
        PORTAB = PORTA                  'Buffer the STATUS OF THE PORT
        '------------------------- ignore errory databits ------------------------
        'using the I2CWRITE command of PBP i got an errory SDA pulse ...
        'using the next line i ignore this error-y line ...
        'for other uses you may ommit it .
        IF SCLB = 0 THEN IOCAF = $00 : RESUME ' IGNORE WHEN CLK = 0
        '-----------------------receive data bit -----------------------------------
        if SCLF = 1 THEN                'CLK_FLAG SET : IT IS DATA !
        '----------------------- store byte ----------------------------------------
         IF BIT_COUNTER.3 = 1 THEN       ' IF WE GET 8 BITS RESET BITCOUNTER
          BIT_COUNTER.3 = 0
          BYTEIN(BYTE_COUNTER) = BYTEINT ' AND STORE THE BYTE
          BYTE_COUNTER = BYTE_COUNTER + 1
          IOCAF.1 = 0                     ' CLEAR INT ON CHANGE FLAGS
          RESUME
        ' ------------------------- receive bit ------------------------------------
         BYTEINT = (BYTEINT << 1)
         BYTEINT.0 = PORTAB.2
         BIT_COUNTER = BIT_COUNTER + 1
         RESUME
        ' --------------------start bit-----------------------------------------------
        IF SDAB = 0 THEN
          BIT_COUNTER = 0
          IOCAF.2 = 0                     ' CLEAR INT ON CHANGE FLAGS
          RESUME
        '---------------------stop bit ----------------------------------------------
          STOPFLAG = 1
          BYTES_RECEIVED =  BYTE_COUNTER
          'BYTE_COUNTER = 0               'nevermind BYTECOUNTER WILL RESET AT THE NEXT START BIT ANYWAY
          RESUME
    ENABLE
    Feb 2010
    I must note i used a 12F1822 @32 MHz and the I2Cbus was running at slow speed !. I don't think the code is fast enough for a 400KHz bus!
    USA - Arizona
    For those who are interested, I placed my implementation here: http://www.electro-tech-online.com/b...mitations.html
