Simple interrupt
Results 1 to 11 of 11
    Aug 2008
    Default Re: Simple interrupt
    True but at 20 mhz that 2.5 seconds seems more like 1 second, Also I can lower this to say 1000 and it still works well. A less than elegant solution, I know, but I am not a programmer. If I am unsatisfied with it on the road then I may try a relay attached to the brake switch that controls mclr. I just thought that in PicBasicPro you could enter a few simple lines of code like ON INTERRUPT GOTO START and it was as easy as pie, I guess not. Everyone says read the spec sheet on the chip, well I have downloaded them and I am still lost. I guess I am just to damn old to understand it.
    Aug 2003
    At 20 Mhz, that 2.5 second delay is only going to be half a second... much more acceptable.
    Didn't see that in your comments before.
