I need help on the compare module
Results 1 to 8 of 8
Threaded View
  1. #7
    Smile Re: I need help on the compare module
    Quote Originally Posted by chitalula View Post
    On my project i dont want to know whether the output is low or high but
    i want to know exactly magnitude of output voltage, to know the magnitude of output voltage after comparison
    I need someone to help me, anyone who is able to provide a sample code to overcome this problem
    Comparator OUTPUT voltage is either LOW ( ~ VSS ) or HIGH ( ~ VDD ) ...
    That's all !!!
    as stated before ... if you need the difference between the two INPUTS , the A/D converter has to be used and difference CALCULATED ...
    no problem here ... except your goal is " not so clear " ...
