I2CWRITE using SSP ?
Results 1 to 2 of 2
    Hangover, Germany
    Default I2CWRITE using SSP ?
    Hello,
    I have a projekt, were I have to divide the current Controller into two parts:
    The first part is the main Controller with the most parts on it,
    the second part is a little display and some buttons several meters away.
    I use a I2C-interface on both controllers.
    I change the existing LCDOUT-commands into I2CWRITE-commands...
    First I noticed, the I2CWRITE-command doesn't support the extensions like SEROUT2 (DEC, BIN...). :-(
    And I think, the hole I2C-part is solved in software. Is there any way in PBP to use the hardware in the SSP ? (on the display-controller I programmed the slave-Mode interrupt-driven by using the hardware...)
    Quote Originally Posted by BigWumpus
    Hello,
    Acces the internal register or use the assembly example in your datasheet. Unfortunately, PBP don't have this built-in function as HSEROUT or HPWM. Could be an interesting future PBP statement since many PIC have this module now.
  1. I2CRead & I2CWrite not working as expected
    Last Post: - 27th October 2021, 19:36
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. PIC 18F4550 and MCP23017
    By DaveC3 in forum Code Examples
    Last Post: - 4th December 2010, 15:01
  4. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 22:40
  5. I2CWRITE and I2CREAD
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2004, 03:30
