ProblemwithPWMfrequency
Results 1 to 38 of 38
    Oct 2011
    Default Re: ProblemwithPWMfrequency
    Thankx HenrikOlsson
    I really appreciate your effort on this forum.
    (1) sorry I understand you explaination very well on how dutycycle relate with value of PR2. one problem is that you statements below is not clear to me and why PR2*4=100%:
    the two lowest significant bits (CCP1CON<5:4>) adds 2 bits (or 4 times if you will ) worth of resolution. So if you prefer you could say that a DutyVal of PR2*4=100%.
    For example, DutyVal=800. Take the 2 low bits and stuff them CCP1CON5:4 and take the 8 high bits in stuff them in CCPR1L. If you take a close look at the 8 bits alone you'll see that it's the value 200.
    a
    (2)From what I know for 8bit resolution
    CCP1CON.4 = duty.0
    CCP1CON.5 = duty.1
    CCPR1L = DUTY >> 2
    that is means that 2bit (CCPICON<5:4>) and 6bit obtain after shifting right(divide by 4) duty value are combine to form 8bit resolution
    What I want to know is that, if I used 10 bit resolution is that code here correct?
    CCP1CON.4 = duty.0
    CCP1CON.5 = duty.1
    CCPR1L = DUTY
    that is 2bit(CCPICON<5:4>) are combine with 8bit (CCPR1L)from duty value to form 10bit resolution.
    thankx
    I'm not sure how to explain this in any other way....
    If you have a WORD sized variable with a 10bit value stored in it you take the two lower bits and put them in CCP1CON5:4. Then you shift the value to the right twice and then load the value to CCPR1L.
    0000001100110010
    Above, the value 818 is shown in binary. The first thing that you do is take the two lower bits (the ones in green) and load them to CCP1CON.4 and CCP1CON.5. Then you shift the value to the right twice which makes the two green bits "dissappear" and two "zeros" shifted in at the high end. The value now looks like this:
    0000000011001100
    Now you load the value (204) to CCPR1L. The code is just as it always been
    DutyVal = 818
    CCP1CON.4 = DutyVal.0   'Lowest significant bit
    CCP1CON.5 = DutyVal.1
    CCPR1L = DutyVal >> 2   ' Shift value to the right twice and move it to CCPR1L
    You may remember that an instruction cycle is 4 clock cycles. Ie, when running with a 20MHz crystal the "execution speed" is 5Mhz. This is because there's 4 clock cycles to each instruction cycle. Normally TMR2, which is used for the PWM generation, is clocked at the instruction cycle rate but in PWM mode it gets concatenated with the 2 bit internal Q clock used to "derive" the f/4 clock. So in PWM mode you could think of TMR2 is a 10bit timer operating at 20Mhz (in this case). The 8 most significant bits of the timer is the TMR2 register and the two low significant bits are the internal 2 bit Q clock.
    The value of this 10 bit TMR2 gets compared to the 10 bit value consisting of 8 bits in CCPR1L and 2 bits in CCP1CON.
    It's all in the datasheet:
    Name:  PWM block diagram.jpg
    Do you see the TMR2 register (8 bits) and the two bits of the Q clock? This forms the 10bit timer. Above that you have a comparator which compares the 10bit timer value with the 10 bit dutycycle value built up from CCPR1L and the two bits in CCP1CON. When there's a match the output goes low. CCPR1H buffers CCPR1L at the start of each cycle so that you can safely update CCPR1L at any time without disturbing the output.
    May I suggest you also take a look at the PIC Midrange manual and I'm sure there are multiple application notes on Microchips website describing the PWM generation in far more detail and far more accurately than I can.
    Oct 2011
    Hi HenrikOlsson
    I have manage to combine the code,compile it successfully and get the correct PWM frequency(5khz) thanks for all.
    (a) As you told me early the DutyVal of PR2*4=100% that means that my value of PR2=199 the DutyVal can vary within (0-796).One problem I have is in my lookup table the there is value greater than 796.What happen to this values greater than 796?
    (b) Also I have read PIC Midrange manual(http://ww1.microchip.com/downloads/e...doc/33023a.pdf) page 211 and 212 it says
    (1) " If the PWM duty cycle value is longer than the PWM period, the CCPx pin will not be cleared. This allows a duty cycle of 100%".
    (2) " Any value greater than 255 will result in a 100% duty cycle".
    is this two reason cause some part of my wave form not to have a PWM frequency of 5khz? having a long off time
    here is code and two phase PWM output
    STEPCOUNT var byte
    STEPCOUNT1 var byte
    LED1  VAR  PORTB.1
    STEPCOUNT = 0   'pointer for phase one in sinearray
    STEPCOUNT1 = 12 'pointer for phase two  in sine array
    ADCON0 = %00000000
    ADCON1 = %00000000
    TRISB = %11111101
    TRISC = %11111001  'PMW output for CCP1 AND CCP2
    TRISA = %11111111
    TMR2 = 0
    PR2 = 199 'generate 5khz  'set for 18Khz HPWM
    CCP1CON = %00001100 'set CCP1 for PWM OPERATION
    CCP2CON = %00001100 'set CCP2 for PWM OPERATION
    T2CON = %00000100  'TIMER2ON and prescale of 1:1
    sineval var byte[36]
    sineval[0] = 512
    sineval[1] = 583
    sineval[2] = 652
    sineval[3] = 717
    sineval[4] = 775
    sineval[5] = 825
    sineval[6] = 866
    sineval[7] = 896
    sineval[8] = 915
    sineval[9] = 921
    sineval[10] =915
    sineval[11] =896
    sineval[12] =866
    sineval[13] =825
    sineval[14] =775
    sineval[15] =716
    sineval[16] =652
    sineval[17] =583
    sineval[18] =512
    sineval[19] = 441
    sineval[20] = 372
    sineval[21] = 308
    sineval[22] = 249
    sineval[23] = 199
    sineval[24] = 158
    sineval[25] = 128
    sineval[26] = 109
    sineval[27] = 103
    sineval[28] = 109
    sineval[29] = 128
    sineval[30] = 158
    sineval[31] = 199
    sineval[32] = 249
    sineval[33] = 308
    sineval[34] = 441
    sineval[35] = 512
    timerone var word
    Temp var byte
    Temp1 var byte
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System          emp
    INCLUDE "ReEnterPBP.bas"
            INT_Handler   TMR1_INT,   _sine,   PBP,  yes
    T1CON = 000001                 ; Prescaler = 1;1, TMR1 ON
    @   INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    timerone =  65080' gives1818hz interruptfrequency or about 50 htz sine
           PAUSE 5
    GOTO Main
    '---[TMR1_INT - interrupt handler]------------------------------------------
    sine:
         T1CON = 000000 'stop the timer
        TMR1L = timerone.byte0  'reload the timer
        TMR1H = timerone.byte1
        T1CON = 000001          ' start the timer
        TeMP = sineval[STEPCOUNT]
        CCP1CON.4 = Temp.0 ' bit 0
        CCP1CON.5 = Temp.1 ' bit 1
        CCPR1L = Temp >>2  'Bit 2-7
        TeMP1 = sineval[STEPCOUNT1]
        CCP2CON.4 = Temp1.0 ' bit 0
        CCP2CON.5 = Temp1.1 ' bit 1
        CCPR2L = Temp1 >>2  'Bit 2-7
        TOGGLE LED1
        stepcount =  stepcount +1
        stepcount1 =  stepcount1 +1
        if stepcount =36 then stepcount =0
        if stepcount1 =36 then stepcount1 =12
    @    INT_RETURN
    Help to help me to solve this problems
    thanks
    You answered your own question in (1) from the Midrange manual:
    Any dutycycle value above 796 will result in 100% dutycycle. In other words your SIN-output will be distorted/clipped.
    Don't think so, I'd expect it to stay at 100% but I may be wrong. However this isn't correct:
    You can't restart at the 12th byte, that will make the second output miss 1/3 of the cycle. You start at the 12th byte to get the correct phase angle offset but you must restart at 0 once it reaches 36.
    Oct 2011
    Thanks HenrikOlsson for your information.But this look like is not clear to me. From what I now when stepcount1 =36 for 2nd phase then stepcount1=12 so as it start to the 12thbyte again because initially is declared as stepcount1=12.What confusing me is that initially in my declaration of variable stepcount1=12 why after one cylecle stepcount1 should declared as stepcount1=0.How can I archieve phase difference of 120 if stepcount=0 after one cylecle.
    You have 36 values in you SIN table. To get a correct output you need each phase to cycle thru these 36 values. You get the phase difference by starting each phase 120° apart in the lookup table but from that point they will keep that phase difference if you reset the index pointer to 0 when they reach 36:
    If you don't reset it to 0 but instead keep restarting the second phase at the 12th value (like you're currently doing) the output will look something like this:
    Why? Because the second phase never "gets" the first 12 values of the lookup table so the output gets A) distorted and B) of another frequency since it doesn't contain the same number of "samples" as the the first phase.
    Thinking even further and adding the third phase, starting at the 24th value keep restarting at 24 the output would look something like:
    I hope you see that the above is not correct and that you understand WHY it's not correct.
    Using your lookup table, starting the pointers at 0, 12 and 24 and restarting them all at 0 when they reach 36 the output looks like:
    Which I think is more inline with what you're after, isn't it?
    Now, the waveform is distorted because you have the value 512 as the first AND as the last the value in the table which means that you'll get a dutycycle of 512 for two "samples" in a row. That is where th flat spot in the wave form is comming from.
    Oct 2011
    Hi HenrikOlsson
    Now Inderstand why stepcount1 should restart to zero.
    (1) But I have been working on the code and and modify my look up table as you told me about the first value and the last value, but the problem of flat spot still remaing I didn't understand why is this?
    (2)If I want to make acertain value of dutycylecle maximum (specific range of variation) let say(0- 80)% or (0-75%) should I do in the look up table or modify the formular?
    formular : ((sin(degree*pi/180)+1) /2)*1023 for 10 bit resolution.
