ProblemwithPWMfrequency
Results 1 to 38 of 38
Threaded View
  1. #9
    Oct 2011
    Default Re: ProblemwithPWMfrequency
    Thankx HenrikOlsson for the comments I worked on on them
    For what I know the gosub coment within subroutine takes two return. The first return will bring you back to the subroutine(TEST) and the second return will bring you to the original gosub comand if I'm not wrong.
    I havebeen worked on the code for almost whole day I'm still getting the same output and I try know my interrupt frequency by Toggling PortB.1 the problem comes I cant see the square wave comes from that pin. here is code and output from ISIS.
    define OSC 4
    Wsave var byte   $70system
    Wsave1 var byte  $A0system
    Wsave2 var byte  $120system
    Wsave3 var byte  $1A0system
    ADCON0 = %00000000
    ADCON1 = %00000000
    LED1   VAR  PORTB.1
    TRISB = %11111101
    TRISC = %11111001  'PMW output for CCP1 AND CCP2
    TRISA = %11111111
    PR2 =  199   'set for 5Khz HPWM
    CCP1CON = %00001100 'set CCP1 for PWM OPERATION
    CCP2CON = %00001100 'set CCP2 for PWM OPERATION
    T2CON = %00000100  'TIMER2ON and prescale of 1:1
    index var byte
    temp var word
    timerone var word
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"
            INT_Handler   TMR1_INT,   _TEST,  PBP,  yes
    T1CON = 000001                 ; Prescaler = 1;1, TMR1 ON
    @   INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    timerone = 64980 ;gives about 50 htz sine
           PAUSE 5
    GOTO Main
    TEST:
        T1CON = 000000 'stop the timer
        TMR1L = timerone.byte0  'reload the timer
        TMR1H = timerone.byte1
        T1CON = 000001          ' start the timer
        gosub display
        CCP1CON.4 = Temp.0 ' bit 0
        CCP1CON.5 = Temp.1 ' bit 1
        CCPR1L = Temp>>2  'Bit 2-7
        TOGGLE LED1
        index=index+1
      if index =36 then index =0
     @    INT_RETURN
     display:
      lookup index,[115,102,90,79,70,62,57,53,52,53,57,62,70,79,90,102,115,128,141,154,166,177,186,194,199,203,204,203,199,194,186,177,166,154,141,128],temp
      return    'return to the subroutine
      return    'return to the original GOSUB
    I don't understand why the output is 2.5Kh instead of 5khz
    help me on that problems
    thankx
