ProblemwithPWMfrequency
Results 1 to 38 of 38
    Oct 2011
    Default Re: ProblemwithPWMfrequency
    Thankx it compile fine but the output is stationary. I 'm confusing why is it.I attach simulation of the output as seen from ISIS
    [CODE]
    define OSC 4
    Wsave var byte $70system
    Wsave1 var byte $A0system
    Wsave2 var byte $120system
    Wsave3 var byte $1A0system
    ADCON0 = %00000000
    ADCON1 = %00000000
    LED1 VAR PORTB.1
    TRISB = %11111101
    TRISC = %11111001 'PMW output for CCP1 AND CCP2
    TRISA = %11111111
    PR2 = 199 'set for 5Khz HPWM
    CCP1CON = %00001100 'set CCP1 for PWM OPERATION
    CCP2CON = %00001100 'set CCP2 for PWM OPERATION
    T2CON = %00000100 'TIMER2ON and prescale of 1:1
    index var byte
    temp var word
    timerone var word
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INT_Handler TMR1_INT, _TEST, PBP, yes
    T1CON = 000001 ; Prescaler = 1;1, TMR1 ON
    @ INT_ENABLE TMR1_INT ; Enable Timer 1 Interrupts
    timerone = 64980 ;gives about 50 htz sine
    PAUSE 5
    GOTO Main
    TEST:
    T1CON = 000000 'stop the timer
    TMR1L = timerone.byte0 'reload the timer
    TMR1H = timerone.byte1
    T1CON = 000001 ' start the timer
    gosub display
    CCP1CON.4 = Temp.0 ' bit 0
    CCP1CON.5 = Temp.1 ' bit 1
    CCPR1L = Temp>>2 'Bit 2-7
    index=index+1
    if index =36 then index =0
    @ INT_RETURN
     display:
      lookup index,[115,102,90,79,70,62,57,53,52,53,57,62,70,79,90,102,115,128,141,154,166,177,186,194,199,203,204,203,199,194,186,177,166,154,141,128],temp
      return    'return to the subroutine
      return    'return to the original GOSUB
    Not that I think it's a problem but why TWO returns in the subroutine? The execution will never get to the second one.
    Are you sure that the output really IS "stationary", it's not just that you have the horisontal sweep set to fast?
    Wrap the ISR in a LED1 = 1 and LED1 = 0 and sample PortB.1 too with your "scope", that way you'll see IF and and what frequency the interrupt ACTUALLY runs as well as how long it takes to execute.
    With 4MHz crystal, PR2 set to 199 and prescaler set to 1:1 you should be getting 5kHz PWM but your "scope" (if I read it correctly) shows a period of 400us which means a PWM frequency is 2.5kHz, why is that?
    Oct 2011
    Thankx HenrikOlsson for the comments I worked on on them
    For what I know the gosub coment within subroutine takes two return. The first return will bring you back to the subroutine(TEST) and the second return will bring you to the original gosub comand if I'm not wrong.
    I havebeen worked on the code for almost whole day I'm still getting the same output and I try know my interrupt frequency by Toggling PortB.1 the problem comes I cant see the square wave comes from that pin. here is code and output from ISIS.
    define OSC 4
    ADCON0 = %00000000
    ADCON1 = %00000000
    LED1   VAR  PORTB.1
    TRISB = %11111101
    TRISA = %11111111
    index var byte
    temp var word
    timerone var word
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
           PAUSE 5
    GOTO Main
    TEST:
        gosub display
        TOGGLE LED1
        index=index+1
     @    INT_RETURN
     display:
    I don't understand why the output is 2.5Kh instead of 5khz
    help me on that problems
    thankx
    No you need one RETURN at the end of the subroutine. That RETURN makes the code return to line after the GOSUB, the @INT_RETURN makes it return from the interrupt handler.
    Are you sure you have the scope connected to the correct output?
    The first thing you need to do i make sure that the PIC and that simulator of yours is running properly and that you're using it properly. Remove all the interrupt and PWM stuff and then make a simple program that just toggles that LED1 output. Connect your "scope" and make sure you can see the output toggle on the scope.
    When and only when you have that working put the interrupt stuff back in but move the TOGGLE command to the interrupt handler - EXACTLY as shown here. Don't try to add all your PWM stuff.
    When and only when you can see that LED1 output toggling on the scope try adjusting the interrupt frequency and see if that works the way you want.
    EDIT: Now make sure that you can setup and control the dutycycle of the PWM module in the main loop (still no interrupts). Just toggle the dutycycle between two values and make sure you can see that on the scope.
    Now, when you have THAT working you are ready to start adding the PWM stuff.
    Don't try to skip a step until you have the previous one working and understand why and how.
    Oct 2011
    Hi HenrikOlsson
    (1) Thankx. I worked on the steps you told me and I manage to control my interrupt frequency which is (50*36=1800) for this frequency the time1 will be loaded with 64980 this value gives me (1667hz) which is the lowest frequency but the value 65080 gives me the frequency 1818. I think as you told me early the PBP tpyes take longer time compared to ASM types ,thankx for it and I deside to use the value which gives (1818hz).
    (2)But sorry you are stastment below is not clear to me.
    Thankx
    2) I mean something simple like this:
      Temp = 40
      GOSUB UpdateDuty
      Pause 500
      Temp = 400
      GOSUB UpdateDuty
      Pause 500
    GOTO Main
    UpdateDuty:
    This should switch the dutycycle between '40' and '400' att 500ms intervals which should be clearly visible on the "scope". Make sure you can do that before you try to move the PWM stuff to the ISR. Since you now know that is interrupt is firing properly and you can control the frequency all you need is to to move it back into the ISR.
    You are making progress but the key is to take it slow and try to understand each step. When something doesn't work, solve one problem at a time and take it slow.
    Oct 2011
    Thankx HenrikOlsson for the comments, and explaination to me
    I have been worked on this code for the whole day but still I didi not get any output. The problem I faced is I don't get any output to the CCP1(TRISC<2>).I tryt to put led1 on main to measure the time I get it clear which is 1sec for each toggle which is true( 500+500)ms also I put led1 on UpdateDuty subroutine also I get clear a delay of 500ms to each toggle which is also true because UpdateDuty it is called aftter every 500ms. But I 'm confusing where is problem? And why is CCP1 does not output to (TRISC<2>)?.Here is the code.
    PIC 16F877
    define OSC 4
    TRISC   = %11111011
    CCP1CON = %00001100
    T2CON   = %00000100
    PR2  = 199 for 5khz
    TRISB   = %11111101
    TRISA   = %11111111
    LED1   VAR  PORTB.1
    temp var word
      Temp = 40
      GOSUB UpdateDuty
      Pause 500
      Temp = 400
      GOSUB UpdateDuty
      Pause 500
      TOGGLE LED1
    GOTO Main
    UpdateDuty:
    Help me to solve this problem thankx.
