Trouble with LCD 2x8 and sequential display of values
Results 1 to 31 of 31
    Dec 2008
    Ploiesti, ROMANIA
    Default Trouble with LCD 2x8 and sequential display of values
    Hello !
    I try to build one volt/termometer with 16F684 and 2x8 characters display. I wrote the code, all works ...fine, the "IN" temperature is shown for 8 seconds, the "OUT" temperature for next 8 seconds, and so on, and so on (the voltage is on second line permanent)....
    BUT : sometimes, the value of temperature "jump" to "0.0 'C", especially when the temperature decreases ?! I really don't understand why . I made many changes in "pause", in "Define LCD_COMMANDUS 2000" and "Define LCD_DATAUS 50" , I added/removed " WaitLoop1: While not DQ1 : Wend" , but without results...
    Any clue ? Thanks in advance !
    This is "the big part" of my code :
    Main :
    Gosub Get_Vbatt                           ' make a new measure
                TmpW = Vbatt * Vfs                    ' AD * 20480
              TmpW = Div32 1024                     '(AD * 20480) / 1024
    Gosub char_batt
            LcdOut $FE, $c0, symb ," ", dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2, " V"
    Gosub StartTimer
    While seconds =< 8
    Part1:
        ' Start temp.conv.Sensor1
         OWOut DQ1, 1, [$CC, $44]
         OWOut DQ1, 1, [$CC, $BE]
           OWIn  DQ1, 2, [temperature1.byte0, temperature1.byte1]
            If Temperature1.15 then
                  Temperature1= ~Temperature1 +1
                  Twist1 = 1
            Endif
        Dummy1 = 625 * Temperature1
        TempC1 = DIV32 10
        TempC1 = (Temperature1 & $7FF) >> 4
        Float1 = ((Temperature1.Lowbyte & $0F ) * 25 )>>2
        Temperature1 = TempC1*100 + Float1
            If Twist1 then
                    V1= 10000 - Temperature1
                  Twist1 = 0
                  V1= 10000 + Temperature1
            EndIf
            If V1 >= 10000 then
                  Temperature1=V1-10000
                  Temperature1=10000-V1
            EndIf
        GoSub SelectSign
               If (temperature1/100) =>10 then
                    LcdOut $FE, $80, "I:", Sign1, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
                    LcdOut $FE, $80, "I:", Sign1, $14, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
                Endif
          Pause 500
    Wend
    While seconds >= 9 and seconds =< 17
    Part2 :
         OWOut DQ2, 1, [$CC, $44]
         OWOut DQ2, 1, [$CC, $BE]
          OWIn  DQ2, 2, [temperature2.byte0, temperature2.byte1]
            If Temperature2.15 then
              Temperature2= ~Temperature2 +1
              Twist2 = 1
            Endif
        Dummy2 = 625 * Temperature2
        TempC2 = DIV32 10
        TempC2 = (Temperature2 & $7FF) >> 4
        Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
        Temperature2 = TempC2*100 + Float2
            If Twist2 then
                  V2= 10000 - Temperature2
                  Twist2 = 0
                  V2= 10000 + Temperature2
            EndIf
            If V2 >= 10000 then
                  Temperature2=V2-10000
                  Temperature2=10000-V2
            EndIf
        GoSub SelectSign
                If (temperature2/100) =>10 then
                    LcdOut $FE, $80, "O:", Sign2, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
                    LcdOut $FE, $80, "O:", Sign2, $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
                Endif
          Pause 500
    Wend
    Gosub ResetTime
    Goto Main
    I have in code "include elapsed.bas" of course...The internal osc is set to 4 MHz.
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Trouble with LCD 2x8 and sequential display of values
    Even in Proteus I see this trouble, if "Out" temperature decreases verry fast ...
    (Just remove final extension of files)
    Dec 2008
    Ploiesti, ROMANIA
    ...or another way to display sequential values of temperature(s), while - on second line- display the voltage ?!
    Have someone another ideea ? Thanks !
    Quote Originally Posted by fratello View Post
    ... BUT : sometimes, the value of temperature "jump" to "0.0 'C", ...
    I have in code "include elapsed.bas" ...
    1-Wire and interrupts don't get along very well together.
    1-Wire has some pretty strict timing requirements, and interrupts like to mess that up.
    You can get good readings, but you have to plan on bad data occasionally.
    Which means verifying the CRC, and checking for all 0's in the packet. The CRC will pass (incorrectly) with all 0's
    You can use the CRC routines from Tom Estes ... http://www.picbasic.co.uk/forum/showthread.php?t=1672
    If the CRC fails, just go back and read the temperature again, no need to do another conversion.
    That of course means you need to read the sensor as a Packet, instead of individual variables.
    You also need to wait for the conversion to complete, either by PAUSE'ING the required amount of time, or polling the busy bit.
    Currently, you are not waiting at all after a conversion command.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for support !
    ...it's another way to do this ?
    I don't think I have enough space for adding something like CRC routines in my code (using 16F684)...
    How about just throw away values that are outside of expected ranges? Like take a running average, and if the temp is way off, disregard it. That way, it can still be 0 deg C, but only if its close to the average temp.
    http://www.scalerobotics.com
    Dec 2008
    Ploiesti, ROMANIA
    Thank you all for support !
    Since the "timming" it's not so important , I made this change :
    Pause 800 ; because DS18B20 need 750 ms for conversion
    Twist1 = 1
    Endif
    ...and the display works fine now...despite the decrease of speed in display the changes of temperatures.
    Dec 2008
    Ploiesti, ROMANIA
    I rushed... still have, from time to time, "0.0 'c" on display, ONLY for sensor on DQ2 (out sensor) .... ....
    Aug 2008
    Portugal
    Why not you poll the busy bit, instead of the Pause 800 statment?
    I don't know your application, but you can also disable interrupts before the 1-wire stuff, and then enable them again.
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    Quote Originally Posted by gadelhas View Post
    Thanks for help ! How can I make this ? The most part of code it's in post #1...
