Don't do that.
I2C requires the pins to be in INPUT mode when not transfering data.
The pins are never driven high, only low, which is why you need the pull-up resistors.
Since it's a 14K50, you're probably running at 48Mhz.
So you may want to add ...
DEFINE I2C_SLOW 1
Depending on if the device you're talking to is a 100Khz I2C part.
If it's a 400Khz part, you won't need it.
