Commands for serial LCD
Results 1 to 3 of 3
    Default Re: Commands for serial LCD
    I use the display often here are some lines from my code.
    Prefix            con     $FE             ' needed before each command
    LcdCls            CON     $51             ' clear LCD (use PAUSE 5 after)
    CursorPS          con     $45             'Cursor Position
    Backlight         con     $53             ' Backlighting 1-8
    Contrast          con     $52             ' Contrast 1-50
    SEROUT2 LCD,84, [Prefix,CursorPS,0, "Print Text Here"]
    pause 2000
    Serout2 LCD, 84, [Prefix,LcdCLS]'Clears screen
    May 2011
    Thank you for the help. The issue was with me doing something I should have known not to do. I was using the internal osc at 8 Mhz to run it. I switched to and EC and everything is fine. I thought because of all the text that was showing up fine that everything was good. Another easy lesson learned the hard way. Thanks again for the help.
