It was a nice try, but it doesn't work. The crystal is not oscillating. (I looked with a scope.)Here is one that should work for you. PBP3 makes it easier, once the configs are right. Just put this into your code.
Also the PicKit2 was complaining about incorrect configuration values.
However, most of the problems are solved now, since I can change the configuration with the Epic programmer software.
One has to improvise sometimes...
