Noise on input signal
Results 1 to 18 of 18
    May 2011
    Default Re: Noise on input signal
    Hey guys,
    Was just reading online that some people tie each unused pin to ground using a resistor (about 1k)? I tied mine directly to ground. Is this the correct method?
    http://www.piclist.com/techref/logic/xtrapins.htm
    c
    heers
    Mark.
    Apr 2007
    Pennsylvania, USA
    The only real benefit I know if with using a resistor, if you accidentally set the pin to a high state, the pin will be fried due to a direct short to ground. With a resistor the current will be limited and prevent damage to the pin.
    Shawn
