Noise on input signal
Results 1 to 18 of 18
    Feb 2011
    Michigan, USA
    Default Re: Noise on input signal
    If X5-2 is power to your sensor, then maybe try a capacitor there.
    But first I would try what aratti said and use bigger caps by the regulator.
    Mike -
    May 2011
    Thanks guys. I will try your suggestions. I will double check the TRIS registers to ensure they have the correct setting. By the way C11 is connected directly to Pin 14 and the input signal is from a low impedance source.
    Bombay, India
    You need to check your grounding paths. If this circuit is built on a breadboard, it may not be easy to resolve this. Ground loops are a concern in most ADC problems. Try to get your ground routed like this
    Input -> 7805 -> Output transistor -> Microcontroller.
    Any changes in this sequence can contribute to the problem.
    Another possible problem is the rate at which you read the ADC. Do you filter the readings you get ??
    May 2011
    Hi Jerson, yep have tried ground planes on a PCB. Slight improvement but same issue. Good point regarding sampling rate. Its 50us as defined in the code. The source has inbuilt filtering. I don't use any averaging of the sampled data.
    Someone online mentioned that the PWM setting can affect the ADC?
    thanx
    Bombay, India
    No, the 50uS is the sampling time. If you happen to read your ADC at varying intervals(due to different paths of code execution), that affects the reading stability. Try to put the ADC read inside an ISR so that it reads at a constant rate. Then perhaps the coupling will break and get you stable readings.
    May 2011
    Hmmm...have tried the suggestions and still same problem. The interference is definitely induced by the strobe pulse. When the strobe is not triggered the signal is fine. Very strange.
    Bombay, India
    can you post your code? Might help identify any issues in code if present.
