Noise on input signal
Results 1 to 18 of 18
    May 2008
    Italy
    Default Re: Noise on input signal
    Did you set all the unused pins as outputs (using the tris register) and set them to low? If not please do it! Never leave floating inputs. If they cannot be set as outputs, then you must ground them.
    Cheers
    Al
    May 2011
    Hi Al,
    Went back and grounded the unused pins. Still get the pulse on the analog signal. Anything else I missed?
    cheers
    Mark.
    May 2008
    Italy
    Is C11 (decoupling) connected directly to pin 14 ?
    Add a large capacitor to the output of your regulator ( say 220 uF)
    X5-3 point goes to a pic pin. Is it an input? If yes and you have nothing connected to the terminal, then you have to ground or pullup also X5-3
    Cheers
    Al
    Dec 2007
    Finland
    Quote Originally Posted by aratti View Post
    Another vote for pull-up or pull-down (some high but reasonable value would be OK). Floating input will see your LED transient (voltage/current change) and interpret that as an input signal (=working as a sensitive receiver).
    -Gusse-
    Feb 2011
    Michigan, USA
    If X5-2 is power to your sensor, then maybe try a capacitor there.
    But first I would try what aratti said and use bigger caps by the regulator.
    Mike -
    May 2011
    Thanks guys. I will try your suggestions. I will double check the TRIS registers to ensure they have the correct setting. By the way C11 is connected directly to Pin 14 and the input signal is from a low impedance source.
    Bombay, India
    You need to check your grounding paths. If this circuit is built on a breadboard, it may not be easy to resolve this. Ground loops are a concern in most ADC problems. Try to get your ground routed like this
    Input -> 7805 -> Output transistor -> Microcontroller.
    Any changes in this sequence can contribute to the problem.
    Another possible problem is the rate at which you read the ADC. Do you filter the readings you get ??
