DHT-11 Humidity/temperature sensor and PIC16F628
Results 1 to 7 of 7
    Feb 2012
    Default DHT-11 Humidity/temperature sensor and PIC16F628
    I started to experiment with the cheap DHT-11 humidity/temperature sensor.
    Unfortunately, there are not very much code examples available in PicBasic.
    I have slightly adapted this code that I found on the Internet.
    INCLUDE "modedefs.bas"
    DEFINE OSC 20                     ' declare xtal to give exact delays
    ip      var    Byte               ' hi pulse from sensor
    temp    var    Byte
    hum     var    Byte
    hum1    var    Byte
    chksm   var    Byte
    test    var    Byte
    i       var    Byte
    TRISB.0 = 0                       ' PORTB.0 = output, OneWire sensor
    TRISB.1 = 0                       ' PORTB.1 = output, serout
    Pause 1000                        ' give sensor time to settle
    mainloop:
    chksm = 0
    '  TRISB.0 = 0                    ' portb o/p
    PORTB.0 = 1                       ' make high
    pause 50                          ' wait for a while
    PORTB.0 = 0 : pause 18            ' send 18ms low
    PORTB.0 = 1 : pauseus 30          ' send 30us hi
    PulsIn PORTB.0, 1, ip             ' wait for hi
    If ip < 130 Then GoTo subloop     ' if < 80us loop
    ip = 0
    For i = 7 To 0 Step -1            ' 8 bits (1..8)
      PulsIn PORTB.0, 1, ip           ' receive pulses from sensor
      If ip > 70 Then
        hum = hum | 1 << i            ' SetBit hum, i
      Else
        hum = hum xor (1 << i)        ' ClearBit hum, i
    EndIf
    Next i
    For i = 7 To 0 Step -1            ' 8 bits (9..16)
      PulsIn PORTB.0,1, ip            ' receive pulses from sensor
      If ip > 70 Then
        hum1 = hum1 | 1 << i          ' SetBit hum1, i
      Else
        hum1 = hum1 XOR (1 << i)      ' ClearBit hum1,i
    EndIf
    Next i
    For i = 7 To 0 Step -1            ' 8 bits (17..24)
      If ip > 70 Then
        temp = temp | 1 << i          ' SetBit temp, i
      Else
        temp = temp xor (1 << i)      ' ClearBit temp,i
    EndIf
    Next i
    For i = 7 To 0 Step -1            ' 8 bits (25..32)
      If ip > 70 Then
        temp1 = temp1 | 1 << i        ' SetBit temp1, i
      Else
        temp1 = temp1 xor (1 << i)    ' ClearBit temp1,i
    EndIf
    Next i
    For i = 7 To 0 Step -1            ' 8 bits (33..40)
      If ip > 70 Then
        chksm = chksm | 1 << i        ' SetBit chksm,i
      Else
        chksm = chksm xor (1 << i)    ' ClearBit chksm,i
    EndIf
    Next i
    SerOut PORTB.1, 4, ["Check sum = ", #chksm, 13]
    serout PORTB.1, 4, ["Humidity = ", #hum1, 13]
    serout PORTB.1, 4, ["Temperature = ", #temp, "C.", 13]
    test = (temp1 + hum1 + hum + temp)
    If chksm <> test Then serout PORTB.1, 4, ["Checksum error", 13] 'HRSOut "error",13
    pause 3000                 ' give sensor time to settle
    GoTo mainloop
    subloop:
      serout PORTB.1, 4, ["Sensor not ready", 13]
    GoTo mainloop
    I have some doubs:
    The line: If ip < 130 Then GoTo subloop ' if < 80us loop has two values. Which one could be correct? 130 or 80 uS?
    Also I changed SetBit value, bit to: value = value | 1 << bit and
    ClearBit value, bit to: value = value xor (1 << bit)
    (Since PicBasic has afaik not got SetBit and ClearBit.)
    Where do I go wrong? Is there an experienced PicBasic user who can give me a hint?
    Many thanks in advance!
    Default Re: DHT-11 Humidity/temperature sensor and PIC16F628
    This may not help but wouldn't it be more readable to use something like:
    If ip > 70 Then
    hum[i] = 1 ' SetBit hum, i
    Else
    hum[i] = 0 ' ClearBit hum, i
    Next
    Norm
    Feb 2012
    If ip > 70 Then
    Else
    Never thought about this!
    Indeed, this is much easier to read!
    Feb 2012
    Many experiments later it is still not working...
    The problem is that the DHT-11 is not recognised and the code jumps to the label "subloop".
    Nobody got an idea or experience with the DHT-11 sensor?
    (I have programmed the PIC16F628 with this hexfile https://github.com/candrian/Thermome.../ThermometerV2 and then it is working, so the DHT-11 isn't the problem. It is even working with a 4 MHz resonator. But I would like to add some other functions in PicBasic.)
    Oct 2013
    Québec, Canada
    Here is my code and it works.
    Good luck!
    dht var byte[32]
    humidite var byte
    haut var byte
    bas var byte
    temp var byte
    x var byte
    dht11 var portb.0
    TRISB.0 = 0 ' portb.0 = output
    dht11 = 1 ' sortie à 1
    pause 2000 ' wait 2 sec
    dht11 = 0 : pause 25 ' send 20ms low
    dht11 = 1 : pauseus 40 ' send 40us hi
    PulsIn PORTB.0, 1, haut 'reponse du dht-11
    if haut < 15 then goto main
    for x = 31 to 0 step-1 'capture des 8 bits entier humidite
    PulsIn PORTB.0, 1, dht[x] ' 1
    next x
    For x = 31 to 0 step-1 'conversion en 1 ou 0: 14 ou 5
    if dht[x] > 9 then
    dht[x]=1 'partie décimale de la temp toujours à 0
    dht[x]=0
    next x
    humidite=dht[31]*128+dht[30]*64+dht[29]*32+dht[28]*16+dht[27]*8+dht[26]*4+dht[25]*2+dht[24]*1
    temp=dht[15]*128+ dht[14]*64+dht[13]*32+dht[12]*16+dht[11]*8+dht[10]*4+dht[9]*2+dht[8]*1
    LCDOUT $FE,$80,"Humidite = ",#humidite,"% "
    LCDOUT $FE,$C0,"Temperature = ",#temp,"C "
    Oct 2013
    Québec, Canada
    I forgot to mention i'm using a pic16F88 @ 8 MHz. So the pulsin is in 5 us increment (ex.: 14 = 14 * 5 us = 70 us and 5 =5 * 5us= 25 us) etc...
    Feb 2012
    Thank you very much! I will try this and see if it works here!
