Multiplexing indicators
Results 1 to 3 of 3
    Sep 2010
    Las Vegas, NV
    Default Multiplexing indicators
    What I'm trying to end up with is a clock displaying seconds, minutes, hours and maybe a few other things.
    What I've been experimenting with so far is the seconds and minutes displays. The displays are 5082-7300 are hooked up to portc and there LEDs on portd.0 and portb.1. The LEDs are just so I know the program is running. I thought I had a schematic but I saved it in wrong format so I can update it later if needed.
    ''*  Notes   :This program will blink a light on portd.1 at      *
    '*          :about a 1 hz rate w/ LED on portb.1 set to 100cps  *
    ' This program will count from 0 to 59 using porte.0 and porte.1
    ' without writing a 60.
    ' Now trying to get the displays to sequence they look like they're
    ' always on.
    'rearranging port outs to resemble final diagram output on portc
    ' portc outputs one and tens properly when latched from porte.1
    '--------------------------------------------------clock variables
    ticks VAR BYTE
    seconds VAR BYTE
    minutes VAR BYTE
    hours VAR BYTE
    days VAR BYTE
    '-----------------------------------------------my variables
    secondschanged VAR BYTE 'seconds
    x VAR BYTE
    out_tens VAR BYTE
    minutes_changed VAR BYTE 'minutes
    minutes_count VAR BYTE
    tens_minutes VAR BYTE
    out_tens_minutes VAR BYTE
    '---------------------------------------------------testing variables
    led1 VAR portb.1
    led2   VAR portd.0 ' blinks at pause rate
    trisc = %00000000
    trise = %001
    portc = 0
    porte = 0
    cmcon = %00000111 ' comparators off
    adcon0 = %00000000 ' adc off
    adcon1 = %11000110 ' sets AN ports to digital
    ccp1con = %00000000 ' turns comparator module off
    latch_enable VAR porte.0' pin 8 on 16f877a
    second_latch_enable VAR porte.1 'pin 9 on 16f877a
    tens_seconds VAR BYTE ' something for the tens digit to display
    '-------------------------------------------DT interrupt area
    wsave   VAR BYTE    $70     SYSTEM    ' alternate save location for W
    INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ' Include if using PBP interrupts
    DEFINE osc4
    T1CON = %00000001                ; Prescaler = 1:1, TMR1ON
    preload VAR WORD
    preload = 60643 '60643 yeilds exactly 100 Hz w/ 1:1 prescaler
    tmr1l = preload.LowByte
    tmr1h = preload.HighByte
    seconds = 0
    tens_seconds = 0
    minutes_count = 0
    tens_minutes = 0
    '--------------------------------------------increment seconds
    IF ticks > 50 THEN 'seconds counting to 59
         ticks = 0
         seconds = seconds + 1
                 IF seconds > 9 THEN
                 tens_seconds = tens_seconds + 1
                 seconds = 0
          portc = (portc & %11110000) | seconds'tell the port which bits to use
                IF tens_seconds > 5 THEN
                tens_seconds = 0
                minutes_changed = 1
          out_tens = tens_seconds * 16
          trise = %110 ' porte.0
          portc = (portc & %00001111) | out_tens 'tell the port which bits to use
          HIGH latch_enable  ' enable write
          PAUSE 5
          LOW latch_enable 'disable write
          PAUSE 5
    '-----------------------------------------------increment minutes
    IF minutes_changed = 1 THEN
             minutes_changed = 0
             minutes_count = minutes_count + 1
                 IF minutes_count > 9 THEN
                 minutes_count = 0
                 tens_minutes = tens_minutes + 1
         portc = (portc & %11110000) | minutes_count'tell the port which bits to use
               IF tens_minutes > 5 THEN tens_minutes = 0
              out_tens_minutes = tens_minutes * 16
              trise = %101 ' porte.1
              portc = (portc & %00001111) | out_tens_minutes 'tell the port which bits to use
              HIGH second_latch_enable 'disable write
              PAUSE 5
              LOW second_latch_enable
              PAUSE 5
    porte = 0
    TOGGLE led2
    GOTO Main
    '---[TMR1 - interrupt handler]------------------------------------
    ToggleLED1:
               t1con.0 = 0
               t1con.0 = 1
         TOGGLE led1
         ticks = ticks + 1
    @ INT_RETURN
    First, I know it's running fast. I got impatient waiting for the digits to turn over so I sped it up. I'll fix that later.
    The problem I'm having is with the ones digit in the minutes display. In my program I initially set all the indicators to zero but the minutes ones digit sets to a 1 immediately. As the program counts the ones and tens seconds display works well. When it comes time to chalk up another minute the ones digit shows the correct count only for a second, or as long as the seconds display is zero, then goes back to being a 1.
    Can anybody tell me why or how to fix it so the digit retains the correct number?
    Most of the time your thoughts are always welcome.
    Default Re: Multiplexing indicators
    First time through, minutes_changed is not initialized to a value (unless I missed it).
    What if you set it to 0 at the top?
    EDIT: You set it to a byte, maybe you get "unlucky" and hit a 0.
    Sep 2010
    Las Vegas, NV
    It's always the simplest of things that get you. So in case anyone is interested, tt turns out setting TRISE, GPIOE and GPIOC at the end of the main loop solves the problem. I also set TRISE as an input early on but it wasn't necessary.
    ticks var byte
    seconds var byte
    minutes var byte
    hours var byte
    days var byte
    secondschanged var byte 'seconds
    out_tens var byte
    minutes_changed var byte 'minutes
    minutes_count var byte
    tens_minutes var byte
    out_tens_minutes var byte
    led1 var portb.1
    led2   var portd.0 ' blinks at pause rate
    trisc = %00000000
    trise = %111
    portc = 0
    porte = 0
    latch_enable var porte.0' pin 8 on 16f877a
    second_latch_enable var porte.1 'pin 9 on 16f877a
    tens_seconds var byte ' something for the tens digit to display
    define osc4
    preload var word
    tmr1l = preload.lowbyte
    tmr1h = preload.highbyte
    'seconds = 0
    'tens_seconds = 0
    'minutes_count = 0
    tens_minutes = 0
    if ticks > 10 then 'seconds counting to 59
         ticks = 0
                 if seconds > 9 then
                 seconds = 0
                if tens_seconds > 5 then
                tens_seconds = 0
                minutes_changed = 1
          high latch_enable  ' enable write
          pause 5
          low latch_enable 'disable write
          pause 5
    if minutes_changed = 1 then
             minutes_changed = 0
                 if minutes_count > 9 then
                 minutes_count = 0
               if tens_minutes > 5 then
               tens_minutes = 0
              high second_latch_enable 'disable write
              pause 5
              low second_latch_enable
              pause 5
    porte = 0
    trise = %111
    portc = 0
    toggle led2
    GOTO Main
    ToggleLED1:
               t1con.0 = 0
               t1con.0 = 1
         TOGGLE LED1
         ticks = ticks + 1
    @ INT_RETURN
