RGB LED driver, Any comments?
Results 1 to 32 of 32
    Question RGB LED driver, Any comments?
    Hi there,
    I'm thinking of building a RGB LED driver for 8 LEDs. I want to use a PIC16F777 for this task as it has a very convenient 3 hardware PWM channels.
    I've made a little schematic, but have some questions.
    larger image:
    http://users.telenet.be/maxpowa/schema_RGBleds.jpg
    I wonder, are the transistors I've choosen OK for the task at hand? Should I use MOSFETs instead, if so, which mosfets are my best choice?
    I would power the circuit with an MC33269T-3.3 LOW drop 3.3Volt regulator. Is this OK or are there better options to power the circuit?
    Anything missing or other comments?
    Thanks in advance,
    Steve.
    Feb 2003
    Shouldnt the placement of the transistors be transposed.
    PORT D
    PNP collector to +5V feeding emitter to common Anode
    Take the base to 0V via resistor to turn on an LED
    PWM Outputs
    NPN emitter to ground, Collector to R,G,B common cathodes
    Take the base to +5V via resistor to turn on a colour.
    You might also like to take a look at the RGB LED Controller Project http://www.rgbled.org
    I am just waiting for the bits for my kit to arrive
    Just my thoughts.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Dude! You're so right.
    Lack of sleep makes pax go crazy.
    Thanks a bunch, i'll rework it after some sleep... or coffee...
    Feb 2003
    Quote Originally Posted by paxmowa
    Apart from when I am wrong!!!
    PORT D
    Should read
    PORT D
    PNP *EMITTER* to +5V feeding *COLLECTOR* to common Anode
    That'll teach me to reply in a hurry before dashing out to collect the kids from school
    DOH !!!!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thanks for the efford Keith.
    After a bit of sleep and with a cleared head I made up this:
    Updated:
    Swapped PNP and NPN transistors around, replaced BC547 by BD139.
    It aint finished yet i guess.
    I checked the specs for the RGB leds and green and blue chips are rated 3.5 to 3.8 volts, red chip is GaAlAs rated at 1.85 to 2.2 volts. The 3.3 volts from the voltage regulator is to high for the red chip and to low for the blue and green. Will prolly go to 5V supply and put resistors in series with each chip.
    Anyways, thanks again for the help so far,
    UPDATE:
    This is the third version, added resistors in series with each led chip, this should be almost complete i think. Now only add the PIC16F777 and power supply.
    hmmm, I figure there's also the voltage drop over the transistors. about 0.6 volt each.
    So the resistors for blue and green should be 10 ohm and for the red should be something like 82 ohm.
    Getting there... slowly, but getting there none the less.
    Steven
    Sep 2003
    INDIA
    Default RGB LED Drv via RS232
    Hello PAX / Other,
    I am trying a very similar project in which I send a byte (actually 3 bytes for R-G-B) information for each of the color LED via the RS232 Port to form a Colour Combination.
    I am plannig to go about using 3 12F629 for each of the LED's. I am having some problem of communicating the PIC's with the RS232.
    Can anyone share some code samples for the RGB LED out here ?
    regards
    Feb 2005
    Im using a single 12F683 (or 12F675) for controlling the RGB channels and I still have space for an extra potentiometer (for sweep speed) and 2 buttons.
    For PWMing I use PWM instead HPWM, of course if you have 3 HPWM is a little easier, but not much...
    you share a common ground and use a 7805 regulator for the pic, then you can power the regulator and the leds with any value from 5-24V (+ after the resistors)
    I drive luxeon leds without problem
    Have fun
    Jan 2006
    Hey Peu, I'm working on pretty much the same thing with a 12F675 PWMing to 3 Mosfets. Everything is working well except I'm finding when I PWM from GP2 and GP4 the MOSFETs don't really pulse they pretty much just stay on, or switch off when the cycle gets low enough. I'm not sure why, I've poked the ANSEL and CMCON, but it seems maybe the output voltage on those pins is a little different or something. Anyone have any ideas what might be going on? I see you are driving your green channel with GP2, does that work fine for you?
    Feb 2005
    Quote Originally Posted by ERIK
    I used this header in a previous version that used gpio.0 as an adc input and 1,2 and 4 as the pwm channels
    @ device pic12F683, intrc_osc_noclkout, wdt_on, mclr_off, protect_off
    @ device INTRC_OSC_NOCLKOUT
    trisio =%00000001
    ansel =%00000001 'analog off except gpio.0
    cmcon0 =%00000111 'Comparators Off
    pasos con 16
    ciclos con 10
    conta var byte
    puerto var byte
    and this is the routine I use for the led brightness increase:
    for conta=0 to 255 step pasos 'Rise routine
    pwm puerto, conta, ciclos ; puerto is the port to be used
    next conta
    high puerto ; after it reached the top brightness, set port high
    you can use the same routine for decreasing, just change the for next and put a LOW after the loop instead of the high.
    hope it helps
    Pablo
    Dec 2005
    Default Erik
    Try using a 1K pull down from the gate to ground on your MOSFET's. I have found that sometimes they get a little flaky with PWM and the 1K seems to make a huge difference.
    Jan 2006
    Ya did put some 1K's on and found the same thing, that it all worked perfectly. I should've come back to this post with that. Strange that I haven't seen any mention of doing that anywhere else.
    I don't know for sure,
    since i changed my computer I should digg out the old schematics somewhere. But I'm pretty sure that there where pulldown resistors in my design. It's never a good thing to leave the pics pin floating in mid air, which will always cause weird results.
    This being said, does anyone think it's feasable to design a RGB christmas light with 50 channels from one PIC controller, prefferably 16C class? I don't think it can be done. Last year with the 8 channel set-up, it was already clear that the switching between the colours was getting a bit iffy to say the least, colours bleeded a bit from one transistion to another when working with 2 or more colours at the same time. I would use decimal counters to go down the row of leds, but I don't think it could be switched fast enough to at least have a flicker-free view.
    It was programmed like this:
    set pwm for red - green - blue
    turn on all used channels
    wait a few msec
    turn off all channels
    wait a few msec
    etc...
    When I wanted one out of two leds to be red and the other ones blue, I ended up with a light shade of blue and a shade of pink, which made me think the PWM channels didn't ramp down fast enough or something.
    Mar 2007
    Wink I am a new user.Where is the asm or hex code for this cicuit
    I am a new user.Where is the asm or hex code for this cicuit.
    Thank you very much.
    Quote Originally Posted by eduman View Post
    You haven't written it yet!
    Mar 2007
    Smile
    Sorry,
    I don't understand.
    Sorry,
    I don't understand.
    People spend a lot of time learning, building, writing, testing, researching, and repeating that same process until they get the result they are looking for.
    I (as well as many others) would be more than happy to write the code to fit your application, design a circuit, build a board, and I'll even hand deliver it to your house/business/whatever...for the right price!!!
    Or maybe you could just learn it yourself...
    Post your idea for a circuit, and some code to go along with it. We can help you iron out problems.
    There's a lot of people around here that would be more than willing to help you out.
    But, as for me (and most others), I'm not going to do it for nothing.
    One hand washes the other...
    You wash my back, I'll wash yours...
    Do unto others...
    blah blah blah
    Get the picture now?
    Mar 2007
    Thank you for your information.
    T.Jackson's Avatar
    T.Jackson Guest
    Thumbs down Here to make money?
    Do unto others...
    blah blah blah
    You're here to make money? With that in mind a long with your rather rude attitude, I think you're in the wrong place. Not saying that it's not possible to pick up a job or two around here, but with that sort of attitude I wouldn't hold my breath.
    Thumbs down
    Man, you miss the point completely and entirely...way over your head...
    I'm glad you got a good, expensive education. I'm glad that somebody will pay you for your hard learned skills. I hope somebody will recognize you for your many years of effort. I hope those same people recognize you for your years of experience so far. I wish you luck in future electronic adventures. May the demons of evil get confused on their way to your doorstep. I bow to your overwhelming skill and intuition.
    If I may quote a little something I found here on the site:
    Date of Birth: February 8, 1977
    Biography: Fulltime student - Bachelor of Applied Science in IT
    Interests: Cars, Computers, Electronics
    Occupation: Currently not employed
    I like that last line the best!
    T.Jackson's Avatar
    T.Jackson Guest
    Default Err
    You're throwing stones at someone who's struggling to do a degree? Few years ago I drove around in a Twin Turbo charged black Nissan 300ZX and I always had a wallet with "something in it" Now the tables have turned, I now live in a remote location with next to nothing. I'm a struggling full time student.
    In my better years I have contributed a wealth of knowledge to the Silicon Chip magazine and hardly got paid anything. I currently have a software archive of 17 submissions on Planet Source Code. One of which is in the hall of fame section. I did not get paid a penny for them. Knowledge received / knowledge given is what it's all about. Sadly you seem to have no concept of it. "My overwhelming skill and intuition hasn't come easy I can assure you"
    Twin Turbo charged black Nissan 300ZX ----> Wish I could find one of those, I'd even settle for a 280ZX
    In my better years -----> All 30-some of them right? I'm 37, and I've said it before, I'll say it again, I know I don't know squat about nothing and probably never will
    I currently have a software archive of 17 submissions on Planet Source Code. One of which is in the hall of fame section -----> Does somebody hear a personal horn tooting around here somewhere?
    I did not get paid a penny for them -----> Ya think anybody around here does? Well, maybe a select few of the elite...
    Knowledge received / knowledge given -----> My point exactly, ya shmo! 'cept that a good portion of these fools/newb's don't want to do ANY of the leg work themselves...they want stuff handed to them on a platinum plate, a one-way transaction all the way, no thought of meeting halfway. Screw that. I've got better things to do.
    you seem to have no concept of it -----> you still don't get it...'cause whether you realize it or not, I'm laughing...
    T.Jackson's Avatar
    T.Jackson Guest
    Exclamation Lay off the drugs
    Lay off the drugs.
    Lay off the drugs.
    Oh...good comeback there Corky. You come up with that yourself?
    Apr 2003
    Cambridge - UK
    Hey SkiMask, if you can change a busted cam belt and swap a few valves, i have a Twin Turbo charged Metallic Black Nissan 300ZX sitting here with your name on it.
    If you can't or you can't afford to ship it to your location, I'd be happy for you to adopt it - like an adopted pet in an abandoned animal sanctury.
    Ouch! Ya have to hate it when that happens!
    Much as I'd LOOOOOOOVE to fly over and get my hands dirty, I'd have a helluva time trying to drive it back
    Wait a minute...I thought Nissan has always used timing chains instead of belts. I've got a '98 200SX/SE, took it to the shop to buy an oil seal for the crank, asked about getting a new timing belt. They said they'd do it for $5 in labor and do it in 10 minutes. That's when I figured out my engine used chains instead of belts The mechanic said Nissan's have always used chains (then again, he was a bit doofy looking), probably didn't know what he was talking about...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    What a ride! That thing fitted me like hand-to-glove. Doubt too many people would really say much otherwise though. Shame about my current car, he's not all there, just have to ignore it I guess.
    cjurczak's Avatar
    cjurczak Guest
    Seems everyone is using MOSFETs to switch their RGB leds, any reason not to use a darlington pair?
    Quote Originally Posted by cjurczak View Post
    MOSFETs don't have a secondary breakdown when they overheat, so less chance of burning up. Mainly, no base resistor needed, lower drain-source resistance, practically zero gate current required (gate cap's make it draw a bit of current at high freq's, not much though.
    The list goes on...
    T.Jackson's Avatar
    T.Jackson Guest
    Post Metal-Oxide-Semiconductor-Field-Effect-Transistors
    MOSFETS are a voltage controlled current source as apposed to BJT's which are a current controlled voltage source. FETs in general have a relatively higher impedance than their BJT counterparts.
    I think there's a lot of personal preference between the two. I will make a bold statement and say that "BJTs make better audio amplifiers" In many cases, either of the two can be made to work.
    Default ZXLD1350 constant current high power LED driver
    This is a pretty old thread. But thought I would add a link to a constant current driver circuit for 1 watt LED's. There are a couple other products around, but this is pretty low part count, and allows from 1 to multiple LED's, so its pretty versatile. It also accepts 7 to 30 volts. They also happen to use a PIC.
    Project site: http://picprojects.org.uk/projects/hbld/index.htm
    Calculator tool for ZXLD1350 chip: http://www.diodes.com/_files/calculators/zxld1350calcv2.xls
    ZXLD1350.pdf
    Mar 2012
    Default Re: RGB LED driver, Any comments?
    No, however they will require more heat sinking than a Mosfet of equivalent current capacity. Since it is a switch (PWM) the LOW RDSon of most all power mosfets < .1 Ohm Vs a VCEsat of > 1Volt makes it a kinda No Brainer unless all you have are some tip121's? I don't remember which... But @5V gate voltage an IRF 540 is hard to beat for a GP Power Mosfet.
    Doc
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. Scale 8bit ADC RGB LED voltmeter
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2008, 03:37
  5. LCD will not start
