gsm modem with 16f877a
Results 1 to 14 of 14
    Nov 2007
    sri lanka
    Default gsm modem with 16f877a
    dear friends
    i want to interface M1206B gsm modem with pic 16f877a.modem with pc ok.i can send sms using hyperterminal.pc with pic ok i can display "at"
    but pic and modem not suport.i have chang baundrate but donot work.i have find som post but i can't do it.please help me
    thank you
    ' Initialization
    TRISB=%00000000
    PORTB=%00000000
    'Definitions
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    BEGIN:
    PORTB = 0
    HIGH PORTB.7
    PAUSE 1000
    LOW PORTB.7
    HIGH PORTB.6
    HSerout ["AT",13,10] 'TEST COMMUNICATION
    HSERIN 5000,begin,[WAIT("OK")]
    HIGH PORTB.5
    PAUSE 500
    GOTO begin
    'END
    Nov 2007
    sri lanka
    Default Re: gsm modem with 16f877a
    any body help me..
    1. Is your modem communicating with a PC at the specified speed? You seem to use 2400 baud rate...
    2. Do the trick with a second serial port, two resistors (experiment from 10K down to 1K which ever works) to pick the Rx and Tx lines an monitor on a PC terminal. You will see if the commands are received and what the modem answers.
    3. Post the results to check here.
    Nov 2007
    sri lanka
    1.it's works 2400 boundrate with pc.
    2.i can't undertand this trick.
    Modem PIC
    Tx -----------X-----------------Rx
    Rx ------X----|-----------------Tx
    1k 1k
    PC |----|
    Rx-------X---X
    Hope this helps you understand.
    Nov 2007
    sri lanka
    Mr Ioannis now i can send sms (i have 1 mistake rx and tx chang)but now i want to do read sms and high led.please help methank you
    This example subroutine is for Wavecom. You have to check the manual of your GSM device for the correct commands.
    Also this example supposes that the GSM device responds with ASCII characters and not with numbers. OK instead of 0 (zero).
    GSM_Subroutine:
    HSerout ["AT+CMGL=",34,"ALL",34,13] 'Check if there is new SMS. 34 is for " symbol
    Hserin 5000,err,[wait(10,13,10),str command\2]
    if command[0]="O" then return	'If response was just OK, then there was no SMS
    if command[0]="+" then goto read_sms 'If response started with + sign then there was some sms
    err:
    read_sms:
    Lcdout com,line1,"Reading SMS",rep " "\4
    for l=0 to 5:command[l]=0:next l    'Clear buffer
    GoSub Mobile_Number      'get mobile number from setup, to check correct admin number
    HSerout ["AT+CMGL=",34,"ALL",34,13]  '"ALL" is for Wavecom module. Read all SMS
    ' Read Caller ID etc. The timeout value in the HSERIN statement is important.
    ' it takes some time before the phone replies to the AT+CMGL command
    HSerin 5000,ex_sms4,[wait("READ"),skip 4,waitstr command\10,skip 27,STR command\6\13] 'Number is waitstr command\10
    LCDOut com,line1,"Read 1 SMS",rep " "\4,com,line2,"Command: ",str command\6
    sms_delete:
    HSerout ["AT+CMGD=1,4",13]			'Delete all messages
    LCDOut com,line1,"Deleting SMS":pause 150
    HSerin 15000,ex_sms2,[wait("OK")]     'Wait for OK (null)
    LCDOut com,line1,"Deleted SMS ":Pause 1000
    GoTo lcd_cls
    ex_sms2:    'No new message or timeout error
    LCDOut com,line2,"Error",rep " "\11:Pause 1000
    GoTo sms_chk
    ex_sms3:
    LCDOut com,line2,"SMS Check Error":Pause 1000
    GoTo sms_delete
    ex_sms4:    'Wrong Number!
    LCDOut com,line2,"Error phone Nbr":Pause 1000
    GoTo sms_delete
    I repeat again, study your GSM AT commands before attempting anything.
    Nov 2007
    sri lanka
    Mr.Ioannis
    I HAVE FIND SOME CODE ABOUT AND I WROTE SOME CODE "AT+CMGD"
    I SEND TO MODEM TO SMS "A" BUT NOT TURN ON PORTB.6
    WHAT'S THE WRONG THIS CODE HELP ME
    ' Def
    define OSC 4
    DEFINE HSER_CLROERR 1
    sms VAR BYTE[16]
    I VAR BYTE
    'Check sms
    begin:
    HIGH PORTB.7
    HSerout ["AT",13,10]' start comm
    HSERIN 2000,begin,[WAIT("OK")]
    LOW PORTB.7
    query:
    HSEROUT["AT+CMGL=",34,"REC READ",34,13,10]' filter for query
    HSERIN 5000,query,[WAIT("REC READ"),skip 41, STR sms\16\13]
    HIGH PORTB.5
    PAUSE 200
    LOW PORTB.5
    I=0
    WHILE I <> 13' count until 13
    if sms[i]=$44 THEN ' searching for letter A ?
    GOTO turnon:
    GOTO back
    I=I+1
    WEND
    turnon:
    High PortB.6
    HSerout ["AT+CMGD=1",13,10]
    low portb.6
    GOTO QUERY
    back:
    HIGH PORTB.4
    PAUSE 100
    LOW PORTB.4
    GOTO QUERY
    xxxxx.
    Are you sure the x y z modem that you have not study yet, is working at 2400 ?
    I am sorry but cannot guess. Nor I have the magic ball to tell me what you have, how it must be set-up. It is your job to do it.
    Feb 2010
    First make sure you connect the pic rx and tx trough 10k resitor to the modem's rx and tx pin, Then you need to tie the handhaking pins together on the modem side.
    Start with pin 7 and 8 tied together and see if u get some data if not then tie pins 4 AND 6.Most modems required handshaking by tieing these pins the modem will be always ready to send and receive other wise it will sit and wait. Good luck hope this will help.
    Nov 2007
    sri lanka
    my sms project
    3 input and 3 out put
    Nov 2007
    sri lanka
    HI.
    how to get tower infomation modem,anybody help me.
    thank you
    kumara
    Nov 2007
    sri lanka
    CHECK:
    portb=%11110000
    HSEROUT ["AT",13]
    HSERIN 5000, ERR, [WAIT("OK")]
    pause 200
    PORTb=%00000000
    HIGH PORTB.4
    PAUSE 15000
    HSEROUT ["at+cmgs=",34,"07xxxxxxxxx",34,13]
    PAUSE 100
    HSEROUT ["SYSTEM OK",26]
    HSEROUT ["at+cmgs=",34,"0719099795",34,13]
    PAUSE 100
    low portb.4
    'get initial status
    PortDStatus.0 = PORTD.0
    PortDStatus.1 = PORTD.1
    PortDStatus.2 = PORTD.2
    BEGIN:
    HIGH PORTB.7
    PAUSE 200
    LOW PORTB.7
    if PORTD.0 != PortDStatus.0 then 'sensed change in PORTD.0
    pause 10 'debounce 10 ms
    PortDStatus.0 = PORTD.0 'save new status for PORTD.0
    if PORTD.0 = 1 then
    gosub SEND_SMS0 'send new status report
    else 'PORTD.0 = 0
    gosub SEND_SMS2
    if PORTD.1 != PortDStatus.1 then 'sensed change in PORTD.1
    pause 10
    PortDStatus.1 = PORTD.1 'save new status for PORTD.1
    IF PORTD.1 = 1 then
    gosub SEND_SMS1
    else 'PORTD.1 = 0
    gosub SEND_SMS3
    if PORTD.2 != PortDStatus.2 then 'sensed change in PORTD.1
    pause 10
    PortDStatus.2 = PORTD.2 'save new status for PORTD.1
    IF PORTD.2 = 1 then
    gosub SEND_SMS4
    else 'PORTD.1 = 0
    gosub SEND_SMS5
    PAUSE 10
    Hero000's Avatar
    Hero000 Guest
    Quote Originally Posted by kumara View Post
    my sms project
    Attachment 6608
    kumara"" I'm highly interested about it, please tell me about its working formula, efficiency etc.
