help me I need code Sim900 + PIC16F877A
Results 1 to 7 of 7
    Jun 2012
    Default help me I need code Sim900 + PIC16F877A
    Help me
    I need code Call phone and SMS
    use PIC16f877A X = 4MHz
    and SIM900 use = http://www.micro4you.net/product-SIM...-138527-1.html
    Thaks
    Jun 2012
    Default Re: help me I need code Sim900 + PIC16F877A
    It code don't work
    it's wrong...
    DEFINE HSER_SPBRG 25 ' 9600 Baud @ 4MHz, 0.16%
    TRISC = %01000000 'set portc.6 TX
    CALL_PHONE : pause 2000
    HSEROUT ["atd[000000000];",13] '00000000 = number
    pause 2000
    goto CALL_PHONE
    thank for help
    I think you have to make sure that there is communication with the module.
    Did you check that the module is responding?
    Jun 2012
    I can not check Module
    I can use X = 4 MHz for buad rate 115200 bps ??
    RX & TX is TTL level I can connect Module to PIC16F877A or module to max232 ??
    thanks for help
    sorry i bad eng
    I am on a mobile phone and cannot check data sheet for you PIC but I thing you cannot use 115k with 4Mhz xtal.
    As for the TTL level use it directly to Pic without max232.
    Quote Originally Posted by lambertodini View Post
    Good job,I appreciate your work because i have the same problem,but your post solve my problem.Thanks for sharing information,your information increase my knowledge.
    Then can you post your code to help him back?
    Robert, I think you are a teaser, aren't you?
  1. Replies: 0
    Last Post: - 6th November 2012, 12:06
  2. Hello Can any one help me with this code (DS1307 RTCM With PIC16F877a)
    By Ali Al-Shaybani in forum mel PIC BASIC Pro
    Last Post: - 20th September 2010, 14:48
  3. Replies: 11
    Last Post: - 6th November 2008, 10:27
  4. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 16:09
