Program for controlling analog servo motor using PIC18F452
Results 1 to 6 of 6
    Jan 2012
    Default Program for controlling analog servo motor using PIC18F452
    hi
    i am using pic 18f452 to control the servo motor Turnigy TG9e.
    i am programming it using microcode studio.
    i was not able to move the servo motor.
    i don't know what was the mistake.
    can anyone provide me a basic program in microcode studio for controlling servo motor Turnigy Tg9e using pic 18f452
    Aug 2008
    Portugal
    Default Re: Program for controlling analog servo motor using PIC18F452
    Quote Originally Posted by SolaiKannan View Post
    hi
    I think its better you put here the code that you allready have, and if possible schematic also!
    Thanks and Regards;
    Gadelhas
    Jan 2012
    this is my coding.
    define osc 20
    OUTPUT PORTB.0
    LOOP:
    PULSOUT 0,110
    PAUSE 1000
    PULSOUT 0,120
    PAUSE 1000
    PULSOUT 0,130
    PAUSE 1000
    PULSOUT 0,140
    PAUSE 1000
    PULSOUT 0,150
    PAUSE 1000
    PULSOUT 0,160
    PAUSE 1000
    PULSOUT 0,170
    PAUSE 1000
    PULSOUT 0,180
    PAUSE 1000
    PULSOUT 0,190
    PAUSE 1000
    PULSOUT 0,200
    PAUSE 1000
    GOTO LOOP
    Jan 2012
    this is my schema .
    Looks like your motor ground is isolated from ground by capacitors and DC will not flow through those.
    Moreover your servo is powered between +V and +V ... ( yes, I wrote it fine !!!) ... and the reset pin can't do its job ...
    your program won't work fine as servo signal ( 1 to 2 ms pulse ) has to be sent every ~ 20 ms ... and not once every second ...
