Discovering devices on a bus
Results 1 to 7 of 7
    Sep 2007
    Waco, Texas
    Default Re: Discovering devices on a bus
    Great ideas and I appreciate the discussion. I understand the 'random' addressing of the IO boards on the chain but for my project I HAVE to have them in a linear order. For example: the 1st board is 1024, 2nd board is 1040, the 3rd board is 1056, etc. This is because I have to know what the address is of the outputs and the inputs on the board (there are 16 each).
    The addressing rotary switch idea will work but then if I forget to address a board or if I quickly address it, there will be conflicts on the bus.
    An idea I have been working is if I have a 485 network in half-duplex mode (less bus collisions), but have 2 serial channels on each IO board. The Master talks to the 1st board via the 485-IN, then the 'chain' continues to the next board by going out a 485-OUT which is connected to the next board and so on.
    For the hardware I plan on using an 18F part
    The MASTER will initiate a command and the 1st board in the chain will answer, get its address unless it already has one, and then merely acts as a forwarding node on the chain.
    This looks like it will work but my question now is at what latency cost? I have successfully driven the 485 at 57.6K but it will take some CPU time to read in the packet and transmit it back out on the chain.
    This method while adding network latency, does overcome the total number of slaves on the network as each IO board starts over <grin>.
    Criticisms or comments? Any further thoughts?
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Dec 2005
    This is from memory so it may be slightly off but here's how ADI does it for their RS485 devices. Activated devices have addresses from 0-252 (I think) with no gaps. All start with an address of 253 (FE) and as they are added to the network, the master sends a command to FE assigning it the next available address. A variation might work for your purposes.
    Looks like they have revised it since I worked with it about 12 years ago. See Section 5.2 (p77) in their manual.
    Nov 2008
    I've not had a chance to do much more on this but my though's were
    All slaves have fixed unique addresses, they also have a broadcast address to listen in to
    The master broadcasts a start new discovery command - slaves wait a random time and respond to master with their address
    After a period of time the master then attempts to talk to each discovered slave
    If the master can talk to the slave the slave address is marked as valid and the slave is given a mute command
    The master goes through the remaining discovered slaves as previous step
    The master then issues a retry discovery command - only slaves not muted would respond, again at random time delays
    The Process then repeats until the master can issue a retry discovery command and get no responce from any slaves - assume all slaves discovered.
    Any comments welcolme
