help about error messages
Results 1 to 8 of 8
    Jan 2012
    Default help about error messages
    Hello
    i'm just approaching to pic programming and i tried to compile a .bas file. Compiler give me a lot of error such as
    C:\PBP\16F684.BAS ERROR Line 135: Bad expression.
    C:\PBP\16F684.BAS ERROR Line 155: Redefiniton of LABEL CCP1CON.
    C:\PBP\16F684.BAS ERROR Line 157: Redefiniton of LABEL CCP1CON.
    C:\PBP\16F684.BAS ERROR Line 166: Redefiniton of LABEL CCP1CON.
    C:\PBP\16F684.BAS ERROR Line 168: Redefiniton of LABEL CCP1CON.
    pic is 16f684
    could someone help me to understand the error meaning, or is there a manual or other where i can study the meaning of error?
    Alezz.
    Default Re: help about error messages
    Hi, Fourtech
    Could you provide the full program you've written ???
    This is the minimum requirement for the crystal ball to light up ...
    seriously, looks to be a small typo somewhere ...
    ALAIN
    Dec 2010
    Yes, likely a typo in line 135 but could be elsewhere
    Jan 2012
    following the code that i tried to compile
    DEFINE OSC 8
    '******************** DEFINE CONSTANTS ***********************
    mtheader CON 2400
    mtbit0 CON 600
    mtbit1 CON 1200
    mtspace CON 600
    '******************** DEFINE VARIABLES ***********************
    bit_counter VAR BYTE
    checksum VAR BYTE
    databyte VAR BYTE
    temp VAR BYTE
    blast_ID VAR BYTE
    temp2 VAR BYTE
    '******************** PIN ASSIGNMENTS ************************
    Symbol trigger = PORTA.0 'Trigger button
    Symbol mod_out = PORTC.5 'IR mod output (40KHz) / PWM out
    Symbol tone = PORTA.5 'Piezo indicator, pin
    '******************** INITIALIZATION *************************
    initialize:
    CLEAR
    OSCCON = %01111000
    CMCON0 = 7 'turn off comparators
    ANSEL = 0
    PR2 = 49 'PWM Period (40K=49, 56K=35) (35 to 55)
    CCPR1L = 15 'PWM Duty Cycle (1 to 15)
    T2CON = 4 'Timer2 = ON; Prescale = 1:1
    CCP1CON = 0 'PWM module off
    OPTION_REG = %01111111 'Turn PortA weak pull-ups
    TRISA = %011111 'set PortA directions: all input except for pin 2 (piezo/led)
    WPUA = %110111 'enable weak pull-ups PortA
    IOCA = %000000 'disable PORTA.0 Int On Change
    TRISC = %000000 'set PortC directions: all outputs
    PORTA = %000000
    PORTC = %000000
    INPUT trigger
    OUTPUT mod_out
    OUTPUT tone
    blast_ID = %111111 'team=Green; damage=100
    start:
    '********************* MAIN PROGRAM **************************
    wait_trigger:
    temp = 0
    PAUSE 100
    IF trigger = 1 THEN wait_trigger
    FOR temp = 1 to 15 'hold 3 seconds to charge
    PAUSE 200
    NEXT temp
    charge_beep:
    'emit 4 short beeps when charged
    HIGH tone
    PAUSE 20
    LOW tone
    PAUSE 40
    HIGH tone
    PAUSE 20
    LOW tone
    PAUSE 40
    HIGH tone
    PAUSE 20
    LOW tone
    PAUSE 40
    wait_release:
    PAUSE 100
    IF trigger = 0 THEN wait_release
    countdown:
    pause 3000 '3000ms = 3 seconds delay before kaboom
    detonate:
    For temp2 = 1 to 4
    send_blast: 'send 24 bits
    CCP1CON = 12 'send MT header pulse (2.4mS)
    pauseus mtheader
    CCP1CON = 0
    blast_first_byte:
    databyte = %00101010 'packet_ID=0 (shot); playerID = 42 (GRNDE)
    send_byte: 'send 8 bits (databyte)
    For bit_counter = 1 TO 8 'send 8 data bits MSB first
    pauseus mtspace 'send space -- space between data pulses
    IF databyte.7 = 1 Then trans1
    CCP1CON = 12 'send zero
    pauseus mtbit0
    CCP1CON = 0
    @ rlf _databyte,F
    GoTo bypassx
    trans1:
    CCP1CON = 12 'send one
    pauseus mtbit1
    CCP1CON = 0
    @ rlf _databyte,F
    bypassx:
    Next bit_counter
    blast_second_byte:
    databyte = blast_ID 'team; damage
    send_byte_short: 'send 6 bits (databyte)
    For bit_counter = 1 TO 6 'send 6 data bits MSB first
    IF databyte.5 = 1 Then trans1_short 'read from bit 5
    pauseus mtbit0
    CCP1CON = 0
    @ rlf _databyte,F 'databyte << 1
    GoTo bypassx_short
    trans1_short:
    pauseus mtbit1
    CCP1CON = 0
    @ rlf _databyte,F
    bypassx_short:
    Next bit_counter
    Next temp2
    pause 60000 'wait for 1 minute
    GOTO wait_trigger 'can be reused again now
    Compiles fine over here. At least for a 16F684.
    http://www.scalerobotics.com
    Grenade compiles fine here too ...
    Quote Originally Posted by fourtech View Post
    Rename your source file to something other than the part number.
    PBP need to include a file named 16F684.BAS from the PBP folder.
    But instead it includes your source code again. Creating many duplicates.
    Jan 2012
    Hello Mr. Darrel
    thanks a lot for you suggestion
    did You pbp 2.6 or 2.4 for compiling the code, I'm tring to use pbp 2.6 under melabs ide 8.76.
