problems with I2C.... and ideas why dosent work?
Results 1 to 26 of 26
    Feb 2004
    Germany
    The RTC works in BCD Format.
    If you want to set the date to the 25th. you would have to write $25 not a decimal 25 (which is $19)
    If you write a decimal 25 for the 25th of a month you are in trouble:
    at midnight the RTC will increment the decimal 25 ($19) to $20 (NOT $1A, because we are talking BCD!),
    which results in decimal 32, which is an invalid date in your decimal coding!
    If you want decimal numbers for easier editing/calculation you have got to convert them.
    See the examples you have got.
    regards
    Ralph
    Warrier's Avatar
    Warrier Guest
    Hi Sood:
    Just thought I might ask the obvious... your PIC is running at 4MHz or less, correct? DS1307 has the standard clock frequency and may not run above 4MHz.
    Try making the I2C clock line bipolar by DEFINE I2C_SCLOUT 1.
    You need to allow some time for the write to I2C completion - 10msec may be enough.
    For initialization of a virgin DS1307 take a look at Ms. Neuman's discussion at http://www.picbasic.co.uk/forum/show...ght=non-eeprom
    -warrier
  1. I2C problems
    By Mad_Labs in forum mel PIC BASIC Pro
    Last Post: - 25th September 2005, 06:22
